Philco 624 output transformer
The 624 uses a single 19 tube in a push/pull configuration. The Radioremembered chart only shows the load resistance of 10K when the 19 is used in a single ended application. Would a push/pull transformer such as one for 6F6's also with 10K, work?
Yup your looking for 10K plate to plate load to match a 4ohm vc. The wattage is about 2.5wts. Your chart should say 5k per plate... It's rather unconventional to configure a 19 as a se amp and use the second triode for another application as it's designed to be use as a power output tube.
Now I think I've got it!
Thanks Terry. Working now.
Pat
Dominion Electrohome here in Canada used the 19 in that configuration quite a bit in their higher end early 30's battery sets. I find it odd as well, but it seems to have worked ok. And knowing manufacturers in the depression era, dollars and cents came into play...
There are currently 1930 online users. [Complete List]
» 2 Member(s) | 1928 Guest(s)
