Philco 624 output transformer
The 624 uses a single 19 tube in a push/pull configuration. The Radioremembered chart only shows the load resistance of 10K when the 19 is used in a single ended application. Would a push/pull transformer such as one for 6F6's also with 10K, work?
Yup your looking for 10K plate to plate load to match a 4ohm vc. The wattage is about 2.5wts. Your chart should say 5k per plate... It's rather unconventional to configure a 19 as a se amp and use the second triode for another application as it's designed to be use as a power output tube.
Thanks Terry. Working now.
Pat
Dominion Electrohome here in Canada used the 19 in that configuration quite a bit in their higher end early 30's battery sets. I find it odd as well, but it seems to have worked ok. And knowing manufacturers in the depression era, dollars and cents came into play...
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
