640B e-cap rebuild
Hi guys -
Working on a recently acquired 640B.  Instead of installing e-caps under the chassis, I'd like to re-build the originals since they're still present.  They're the type with the cardboard sleeves under the mounting rings.  I've seen some articles in the library for various techniques but seem to recall older articles that I cannot locate.  Perhaps they were removed when the site was updated a few years ago.  Looking for the best method.  Recommendations?
Thanks all,
https://philcoradio.com/phorum/showthread.php?tid=23702
Look at my post #10, I have just finished this thread.
David - I think I understand but what units are you discussing (Low of 1.7, high of 3.9)? Budget constraints for Ham ...EdHolland — 01:43 PM
My Philco 37-116 Restore
You're doing great. I wish I could be more involved, but my mind is right now preoccupied with the reason I am here in ...morzh — 12:21 PM
Hope you guys are still with me. I have moved on to the alignment. I completed the IF alignment which was pretty muc...dconant — 10:47 AM
Hello MrFixr55, Thank you for taking the time to explain. I measured 50 volts where you say. Today the 370 volts at ...dconant — 12:51 PM
Oh that sucks. It’s something easily overlooked. Hopefully it’s nothing more than a resistor! Ron462ron — 08:08 AM
Just confirmed that you are correct. It’s the function generator. I connected the signal output probe to one of the inpu...jrblasde — 07:52 AM
Ouch, you may be right. Yes, it is solid state. It’s the signal output of my oscilloscope. May be time to crack that ...jrblasde — 07:27 AM
If you didn’t put a DC blocking cap between the signal generator probe and the plate of the 1st IF it’s possible you ble...462ron — 07:07 AM
Hi DConnant, The reason why C127 is isolated from ground is because sets of this vintage did not have the center tap...MrFixr55 — 01:07 AM
The shield is on the 6H6. It was, in fact, a missing jumper to connect the main chassis ground to the RF chassis grou...jrblasde — 10:58 PM
There are currently 1029 online users. [Complete List]
» 1 Member(s) | 1028 Guest(s)
