1st detector winding
Hi, I’m new to the phorum. I’m completing an electronic restoration of a Model 90 (2-45s). The outer winding on the 1st detector coil is open. What is the wire size and number of turns?
Count the turns as you unwind them.
Note the direction. Even if not important, it's a good practice.
Gauge is not superimpirtant.
39-40 is ok.
Welcome to the Phorum, TimG! Another option is to run a needle gently down the coil and count the 'bumps'. Each bump is one turn.
You may want to see the restoration of a Model 90 by our founder, Ron.
https://philcoradio.com/library/index.ph...on-part-5/
Take care and BE HEALTHY! Gary
If you are speaking of the primary of #7 I used 96t of 38g wire.
https://philcoradio.com/library/download...n%2056.pdf
Hi Tim,
Pardon my manners it was kinda late last post. The 1st gen 90's (p/p 45's) and the 2nd (se 47) use the same rf plate coil. The 3rd gen (p/p 47's) has a different IF frequency so I would think some of the rf parts are going to be different. Probably not the rf amp coil.
https://philcoradio.com/phorum/showthread.php?tid=24784
When you have the tuning cap out to replace the grommets under it do take the screws that fasten the stator plates in place loosen one by one and re-tighten one by one. My set had an intermittent problem where the volume would drop down abt 1/2 after a hour of use. 10 or 15 mins later it would resume at full volume. Very annoying. That was the fix.
Have fun chasing electrons!
There are currently 955 online users. [Complete List]
» 1 Member(s) | 954 Guest(s)
