42-345 Resistors
Great comments.
I have a tinkering bench at my office, and that's where Little Phil is right now. I will have to comb through these comments and look at the machine.
I think the resistance on the field goal is 1680 ohm. That's from memory, but I checked both LittlePhil and FrankenPhil, and they were the same.
I can, say, however, that I think hantavirus killed Gene Hackman's wife. I'm hoping the radioactivity from the bomb blasts killed the virus. I have cleaned the case out.
As for "Electronic, electrical and mechanical systems work on smoke. How do I know this? Because when you let the smoke out, the device stops working." On Sunday, I heard this for the very first time from my cousin, who is a mechanic who works on Jags and Rolls Royces. I let him know that there had been plenty of smoke.
Today, I replaced three paper capacitors and a resistor and managed to keep the smoke inside the wires and components. I found out that doing one thing at a time is actually kind of hard, because the next thing you know, there's an old wire from the 1940s that needs replacing. But, I got it done by proceeding slowly and also by confirming wiring by looking at FrankenPhil.
I'll look at the original field coil, cone-free original speaker tomorrow to see if I can understand just where to attach a temporary PM speaker. A little Jensen speaker came in the case with FrankenPhil, so I think the former owner was able to generate sound.
This is fun!
Pholks:
What are these little cylindrical objects inside Little Phil? They seem hollow. I don't think they are capacitors.
Tom
I think they are little inductors. I also think those are antenna coils.
If over caps, see what cap it is, replace and put inside the winding again.
Also, tthey are shown in the corner of the chassis drawing. At least two numbers say 5, 6` and 13.
The quality in the Nostalgiaair is bad, so maybe someone has a better copy; I am away from home so I cannot get to my Riders.
Hi Prof Russell,
Here is a link to the Philco Service Notes for this receiver, from our Philco Library:
This document shows both a schematic and an under-chassis parts diagram.
Per the document, the output transformer is located on the chassis.  One leg of the secondary is grounded.
Therefore, you should have either 3 or more likely 4 wires.  If 3 wires, the speaker would have to be mounted to the chassis to complete the voice coil circuit.  2 of these wires are to the Field Coil.  The other 2 (or one wire and chassis ground) go to the output transformer.  One of these wires connects to one terminal of the speaker's voice coil.  The other wire connects to one leg of the "hum bucking coil", wound with the field coil.  The other leg of this hum bucking coil connects to the other terminal of the speaker's voice coil.  Does this speaker plug in to this chassis or is it "hard wired"?  The Schematic does not show a plug.
For the purpose of testing, the easiest way of connecting a speaker to the radio if you have the original speaker with the missing cone connected is to:
  • Inspect the original speaker and note 2 or 3 terminals on the frame of the speaker.  2 of these terminals are for the voice coil.  Very flexible wires lead from these terminals to the speaker cone if it was still in the speaker.  (You should see these same connections and flexible wires on the test speaker.) If the cone is missing or beyond repair but these flexible wires and the voice coil still exist, cut these wires.
  • Measure between these terminals with the speaker connected to the radio.  This should be a very low resistance, possibly less than 1 ohm.  the speaker can be connected here.  Alternately, there is a connection for the speaker on the antenna terminal.  connecting a speaker between this terminal and chassis ground will also work, but hum may be higher.
Hope this helps.
Mike, Tom - parts 5 and 6 are listed as BC and SW antenna transformers and the chassis parts layout shows them next to each other in the corner. I'm thinking that's them in your photo. The link above has a clearer schematic. Part 31 is listed as a resistor and I didn't see any rf traps (rf coil in series with a capacitor) in the schematic or parts list.
Thank you to everyone who has replied.
The two mystery objects are either mini cannoli or oscillators. I'm not quite sure what they do, but I have not messed with them.
I successfully replaced all of Little Phil's capacitors—well, the electrolytics and paper capacitors. I also replaced about 10-12 of the resistors. I tried to do one thing at a time, but you know that one thing inevitably leads to another. All went well, except for one day when Little Phil went silent. I retraced my soldering and installation and brought the radio back to life.
Little Phil has either a tear in the speaker or, if there are seams in the speaker, a broken seam. I bought two types of glue recommended on other threads—E6000 and Aleene's fabric glue—and I will try either coffee filters or tea bags. I'm going to experiment with my PM speaker first. Once the speaker is patched up, I'll put Little Phil back in the nice wooden case.
FrankenPhil: Having Franken Phil has been a big help in replacing parts in Little Phil. Everyone's instructions re the destroyed field coil speaker are very helpful. Thank you, especially to Mr.Fixr55, who gave me the step-by-step I really needed. The original speaker has three wires going in, so there is a ground to the chassis. I attached a permanent magnet speaker to the two little terminals, as you suggested and mounted the speaker in FrankenPhil. At this point, I get only a wee hum and no audio from the speaker. I'm not entirely sure how to proceed, but I will replace the electrolytic capacitors first and see if that gets me anywhere.
I'm unclear on attaching a speaker to the antenna something-or-other or is it the three little jacks on the chassis? That would be handy to test the sound.
I'm enjoying the smells of the soldering, rosin, the tubes, a wee bit of dust, and the burning smell of the carpet when I drop the soldering iron.
Tom
There are currently 2559 online users. [Complete List]
» 1 Member(s) | 2558 Guest(s)
