This is a nice little Motorola set that appears to be in relatively good shape. None of the external plastic case is broken although the power cord has been cut off.
[Image: https://www.dropbox.com/scl/fi/shvjhrl7t...n2eg&raw=1]
[Image: https://www.dropbox.com/scl/fi/cgovcp7mw...5yil&raw=1]
The outside is very dirty but seems to be cleaning up nicely with some waterless hand cleaner on a paper towel, well, lots of paper towels and cotton swabs.
[Image: https://www.dropbox.com/scl/fi/nmamaisap...vglp&raw=1]
So far the only obvious broken parts are the two red plastic mounts for the front door hinges.
[Image: https://www.dropbox.com/scl/fi/78hk5g63j...j5a6&raw=1]
Here's a close up of the hinge inserted into the space where the hinge mount should be supporting the hinge. I'll have to do some thinking about out to manufacture something to do this. Since the on-off switch for the responds directly to the opening and closing of the front panel on the radio its important to find a fix.
[Image: https://www.dropbox.com/scl/fi/jja1y95nj...t0x2&raw=1]
The underside of the chassis has a nice date stamp of May 4, 1949 and when that panel is removed you get a look at the wiring and components housed there. A lot of stuff packed into a small space so replacing caps is going to be a little difficult.
[Image: https://www.dropbox.com/scl/fi/156mut4ri...tphn&raw=1]
[Image: https://www.dropbox.com/scl/fi/j2cgmt46e...hrp4&raw=1]
Fortunately it looks like all the transformers are still intact (unlike the Philco 39-7 I just set aside),the tubes all test out OK and the loop antenna housed in the front panel ohms out OK.
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!
Joe
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
Vlad; I thought your brown RCA portable looked familiar, I have one that is very similar, the RCA-Victor model BX-55....Arran — 02:31 AM
Value of capacitor
OP is "original poster"klondike98 — 11:05 PM
Value of capacitor
What is an OP?  Looks like the “OP” mistakenly typed electrolytic.  Lets forgive him.Joe Rossi — 06:31 PM
How many amps a man can have? I say, as many as the space can hold.morzh — 10:01 AM
