I'm starting to restore a Philco 16X, I need spare parts. Please, help me find it
Threads: 24
City: Svalyava. Transkarpatia
I'm preparing an old Philco 16X radio console from 1934 for restoration, which unfortunately is in pretty bad condition, but the worst thing is that I need to find a lot of spare parts. Two control knobs are missing, the scale escutcheon is missing, the scale itself is in very poor condition, the output pentodes of type 42 also have weak emission... But the biggest problem is the field coil on the speaker is broken.  . I have little hope that I will be able to repair it... It seems that this project will be too expensive for me, but I really want to buy this radio that they gave me to restore.
Can someone help me buy these spare parts?
Sincerely Peter
З повагою Петро
(This post was last modified: 06-05-2025, 04:06 PM by RadioSvit.)
Where did you get this one from?
I have restored same exact 16X about 2 years ago, the thread is here.
https://philcoradio.com/phorum/showthrea...philco+16x
Threads: 24
Michael, this is one of the five radio consoles from Canada from my companion that I received for restoration and that I have already written about here somewhere. It is this Philco that I plan to buy back as compensation for the restoration services provided. Thanks for the link.
Sincerely Peter
З повагою Петро
(This post was last modified: 06-02-2025, 10:16 AM by RadioSvit.)
Peter;
Are you certain you wouldn't like the Deforest Crosley instead? It's probably the most "Canadian" of the radios this fellow brought you? I'm sure that the parts will come up for the 16X, or is it a 316X given the Robertson screws in the cabinet? I think that the field coil for the speaker could be rewound if you could not find another, though I'm sure there is another out there, Philco used the same speaker in a number of consoles, "H" series I think they were called. The pole piece in that speaker is pressed in, so it could be pressed out, the bobbin removed, and the field coil rewound or repaired.
Threads: 24
Thanks, Arran. Very interesting information about the speaker, I will definitely try to disassemble it if it has a collapsible design. As for the De Forest Crosley ... Yes, it is the most beautiful of the five and I would gladly choose it. But I already have a difficult choice between the RCA Victor 262, Philco16x and the De Forest Crosley. I suspect that I will not be able to choose and will be forced to buy all three.
But considering the cost of delivery to Ukraine, it will be a very expensive pleasure. And considering that I am already retired and do not have any business, it will be difficult to do.
Sincerely Peter
З повагою Петро
Peter;
The Philco (3)16X was likely a Canadian market Philco, which means that Philco Products of Canada LTD likely had the cabinet built in Canada by one of the same furniture companies that built the DeForest Crosley cabinet. The reason I was commenting of the DeForest Crosley being the most Canadian is that the Philco chassis and speaker would be more or less identical to one produced in the U.S, whilst the DeForest-Crosley sets had chassis designed and used only by Rogers, and had those spray shield tubes also made by Rogers. To be fair Rogers did source some parts from the U.S, as most Canadian companies did, but they did things in their own unique way.
Some of their larger models had variable IF bandwidth, with a mechanical linkage moving an inductor inside and out of the transformer cores. I don't think that Philco did this, though they did have squelch on some of the earlier 16 models, calling it "QAVC". Amateur radio enthusiasts were some of the early customers for the Philco 16s in part because of the five, later four bands these sets had, and the fairly reasonable price for what they are getting.
I have a chassis from a 3116X but it does not have the original speaker at all, someone put a pair of 8'' Magnavox speakers in it's place, the original would have been similar to the set you have. I never could get the thing working and put it aside, sometimes you just have to.
Threads: 226
City: Omak
State, Province, Country: WA
Hello Peter,
What great project I am looking forward to see your progress with this console !!
Threads: 270
Hi Peter,
As for the spkr what you are looking for is a U-2 spkr. The H style spkrs are not as robust as the U models. I'm pretty sure I have a U-9 which came out of a 116X. The FC is abt 350 ohms higher than the U-2 and the transformer matches p/p 6A3.
The cone got wet at some point before I got the set. I ended up using it for a test spkr for a while and now it's just sitting somewhere...
I can get it over to Mike as he is abt an hour drive from me.
Over a number of years I've picked up a few of the 16/116B series. These are the tabletop version of your set. Obtw they use the H-13 spkr.
https://philcoradio.com/gallery2/1935a/#Model_16B
Now I think I've got it!
(This post was last modified: 06-05-2025, 07:42 AM by Radioroslyn.)
Threads: 24
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A, chassis number 122. I have just taken a photo of the nameplate and will post it in this thread.
Richard, thank you.
Terry, thank you very much for the offer. I will take another look at the Philco speaker tomorrow and if I cannot repair it, I will gladly buy it from you.
Sincerely Peter
З повагою Петро
Peter;
I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets had those but many did. It should not be a problem operating it from a 50 cps power line though, I would guess that you are using a step down transformer, or autotransformer to drop the 230-240VAC down to 120 VAC since you have a number of North American radios in your collection already? I have to do the opposite with a British Kolster Brandes set, it's 200-250 VAC input, so I'm going to use a ballast from a metal halide lamp to step up the 120 to 240 VAC, I just wish I could find a BS 1362 outlet so I can use the original power plug with it.
That speaker looks like it should be rebuildable, the cone is held on with a metal band that is screwed onto the basket, so it should not be too difficult to remove. A bit of acetone around the rim will take care of any cement or paint holding it in. Then it's a matter of getting the pole piece out of the rear bracket. Hopefully it's just a broken wire and isn't burned out, or corroded.
Threads: 24
Do we rejoice in our mistakes? I'm sure we'll all say "No", when we make them we always get upset... But I don't remember being so glad when I realized - I was wrong! Yes, I was wrong when I rejected the field coil of the speaker on the Filco 16 X, it turned out to be intact.  But the primary winding of the output transformer is broken  , but this problem is much easier to solve. Well, I can start repairing the chassis when I have free time.
By the way, - I've already restored the case...
PS. Special thanks and apologies to Terry, it seems that I don't need another speaker anymore. Sorry, Terry.
Sincerely Peter
З повагою Петро
(This post was last modified: 06-27-2025, 12:04 PM by RadioSvit.)
Threads: 24
Hello everyone. I haven't been active in this topic for six months, but during this time I have been quite actively engaged in the restoration of this Philco. In the winter I solved the problem with the worn anode winding of the output transformer. I simply disassembled this transformer and using a simple device with a counter, I unwound and counted the number of turns of the secondary and primary anode coils of the transformer.
The anode primary winding has 2800 turns of wire with a diameter of 0.16 mm or 0.064 inches. The secondary winding has 55 turns with a diameter of 1.0 mm or 0.4 inches. Thus, I calculated the transformation coefficient, which is equal to 50.9.
Over the years of repairing and restoring tube radio equipment, I have accumulated a lot of output transformers from Soviet radios and I was surprised when one of the transformers turned out to have exactly these characteristics, and its ferromagnetic core has even greater thickness and volume, and therefore better inductance and hysteresis characteristics. Therefore, I will probably use this transformer, and not wind the transformer from Philco. Well, at least temporarily, because I don’t have the 0,16 mm thick wire I need right now.
And finally, this winter I made a video on the restoration of this Philco cabinet. Six months after the restoration itself was completed
[Video: https://www.youtube.com/watch?v=vdnVphG-HO4&t=1234s]
Sincerely Peter
З повагою Петро
(This post was last modified: 03-08-2026, 11:04 AM by RadioSvit.)
From the photo, the winding looks like it sustained some real high temp event. Is this it or is it just the lighting?
Threads: 24
That's right, Michael. The winding must have been very hot because not only the varnish but also the wire itself was very brittle due to overheating.
Sincerely Peter
З повагою Петро
Could be the output tube short. Not sure what else would result in this.
| hello david,
| Hello Everyone,
There are currently 2127 online users. [Complete List] » 1 Member(s) | 2126 Guest(s)
