Philco 46-806 audio out
According to the circuit, the audio output is 35A5E valve, I have to replace the valve 35A5, are compatible connections and features two valves?
Shouldn't be a problem all 35A5 where created equal.
And that identifies the "E", that differentiates the two valves.
Best I can tell it's to denote the manufacture.
The "E" stands for European. The characteristics are slightly different than American tubes without the "E" suffix. As an example, the 35A5E will have its suppressor grid tied to the control grid instead of to the cathode.
An American 35A5 should work well in place of a 35A5E.
Doesn't the line voltage in Europe run 250+ volts, and if that is the case, wouldn't foreign sets have been calibrated to run at higher voltages, or were they all internally universally standardized?
The AC/DC 46-806 has a ballast resistor which could be inserted one of two ways in its socket. When the set is operated in the 230 volt position, extra resistance drops the line voltage to 115; in the 115 position, a jumper wire allows the full line voltage to be used in the set.
I have a 46-806 which uses one of these ballasts. My 42-761 also uses a two way ballast - different type than the 46-806, though.
Philco 46-806 In my case, the ballast is in the position of 230 V, corresponding to power Argentina (220 Vca).
I have one of these:
[Image: http://www.wa2ise.com/radios/ph46-806.jpg]
A previous owner/repairman in Lima Peru had changed the tube sockets to accept octal tubes for some of the tubes, and hacked in an autoformer in place of the ballast. I took that out, did a recap, and used a capacitor to drop 230V@60Hz to feed the heater string. And a resistor to drop some the 230VAC for the rectifier (you get more B+ in 230VAC mode, which makes for more audio output with a 35L6 (the above octal replacement) and some more gain for the front end and IF amp.
Thank you Rod and Paul I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM
Philco 45L Initial Check Up
Hello, I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM
Table radio 51C or 52C?
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it.  $5  Unable to fi...antiqueradionut — 05:14 PM
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
There are currently 942 online users. [Complete List]
» 1 Member(s) | 941 Guest(s)
