Reading mica caps
Am trying to determine the value of a mica capacitor on my Model 60B. Reading in the correct order, the dot colors are: Red, blank, Red, with no other colors anywhere on the capacitor. The blank dot is the color of the capacitor's plastic body and I can detect no original color residue. Would the correct reading be 2 0 00pf? Or 2 1 00? Or something else? My schematics don't show any capacitor having this value.
M
See if this helps, if not let me know.
http://www.radioremembered.org/capcode.htm
What model radio is this? It sounds like one of the proprietary codes. If its a Philco look on Chuck Schwark's website. There's a list of their codes.
philcorepairbench.com
From PhilcoRepairBench:
Part number: 7007** Value: 1,400pf (5%) Type 4 (square with axial wire leads) Color code: Red Red
Bill, we having a senior moment? Icon_smile OP listed the model as a 60B in the original post. Icon_smile (don't worry, I have more than my fair share of senior moments.... who am I again?)
BrendaAnnD: I believe you're right. Based on your information, I looked up part number 7007 on Bulletin 164-A and, yes, that's the capacitor. So, is the Red/Red a Philco code?
What lead me to inspect and test this capacitor was my attempt to align the dial marker on 2.5mHz while tuned to the Universal Time Coordinate radio station broadcasting at that frequency. I found that increasing this capacitance aligned the dial marker just right. The AM band is almost perfectly aligned with the dial indicator, which I consider pretty good for a seventy-nine year old set and for a radio technician who's not really a radio technician but just a radiophile.
MD
Yes, that's a Philco code. As Bill said above, all this great information is available at www.philcorepairbench.com/partinfo.htm , a wealth of parts info on most all Philco proprietary parts, including those pesky bakelite caps.
It Works!
Many thanks to all.
MD
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
