New PHILCO 630
Wow looks great. Nice job!
Looks great Jeremy! I'll be working on a 640 which has the same cabinet and am following your progress closely.
- Geoff
Here are a few pictures after just two coats of Formby's tung oil finish on the top, sides, and trim. I'll probably put on a third coat, then do a light scuffing with 4/0 steel wool, then a few more coats. The finish is building up pretty quickly.
Here is the final result of my cabinet restoration. In the end, it only required about 5 coats of Formby's tung oil varnish (I think my supply had thickened a bit, but it didn't seem to affect the final result). I followed up by a rubbing with Howard's Restore-a-Shine and then a coat of paste wax. The cabinet is very dark, making it somewhat difficult to photograph. The result is not quite like lacquer, but I think it is pretty close. Comments welcome, especially on how you think it compares to the more typical toned spray lacquer refinishes.
In looking at the photos, the light lines along the front trim appear more noticeable than they are in reality, though I may go back and touch them up. This is the result of using a pigment stain for coloration rather than toner .
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Need Help to ID this radio 11 tube Philco
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
There are currently 766 online users. [Complete List]
» 1 Member(s) | 765 Guest(s)
