New PHILCO 630
Wow looks great. Nice job!
Looks great Jeremy! I'll be working on a 640 which has the same cabinet and am following your progress closely.
- Geoff
Here are a few pictures after just two coats of Formby's tung oil finish on the top, sides, and trim. I'll probably put on a third coat, then do a light scuffing with 4/0 steel wool, then a few more coats. The finish is building up pretty quickly.
Here is the final result of my cabinet restoration. In the end, it only required about 5 coats of Formby's tung oil varnish (I think my supply had thickened a bit, but it didn't seem to affect the final result). I followed up by a rubbing with Howard's Restore-a-Shine and then a coat of paste wax. The cabinet is very dark, making it somewhat difficult to photograph. The result is not quite like lacquer, but I think it is pretty close. Comments welcome, especially on how you think it compares to the more typical toned spray lacquer refinishes.
In looking at the photos, the light lines along the front trim appear more noticeable than they are in reality, though I may go back and touch them up. This is the result of using a pigment stain for coloration rather than toner .
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
There are currently 907 online users. [Complete List]
» 2 Member(s) | 905 Guest(s)
