Philco 91B Dial Cord Replacement
I need to replace the dial cord on a Philco 91B cathedral I recently acquired. How would I removed the large pulley the dial scale is attached to so I can access the two smaller pulleys. Thanks, Charlie
Should be a set screw on the dial hub.
Philco 89 Code 123 Osc Coil
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
