more 41-250 questions
I got the pushbutton switch assemby removed and after looking over the radio it appears that about 95% of the wires will need replacing.
Is this normal for this particular chassis? How many of Philco's other chassis will have this problem?
Any hints on restoring this radio? It appears that i will have to remove the bandswitch assembly as well.
How many hours does it usually take to restore one of these (caps and rewire)?
Do customers pay what it's worth to restore one of these? The labor cost must be through the roof.
What would a restored radio of this vintage be worth?
I am new to restoring vintage sets. So far I have restored 3. I have been in electronics for 20 years though I am now on disabilility. I am buying a few radios to restore for the experience then hope to repair a few as a business.
Hi
Questions answered inline...
I got the pushbutton switch assembly removed and after looking over the radio it appears that about 95% of the wires will need replacing.
Yes.
All Philco sets made between 1939 and 1942. You can also unsolder one end of each wire, remove the remnants of the old rubber insulation, then resleeve with color-coded heat shrink tubing.
Take your time and be patient. To get at all of the old rubber-covered wiring, sometimes the bandswitch on these models (41-250, 41-255, 41-256, 41-280, 41-285, 41-287, 41-290) must be disassembled, to avoid breaking the bandswitch wafers. You'll also need to disassemble the IF cans and replace or resleeve every wire.
Or disassemble it...by removing the two nuts that hold it all together and then pulling the individual wafers apart...being careful not to lose the spacers that go between the wafer sections...
A LOT. Too many, in fact. Icon_evil
Sometimes yes, sometimes no.
If the job is done right...it has to be, in order to be fair to the person doing the restoration work.
As much as someone is willing to pay for it. And nowhere near as much as the time and effort you must put into one of these to properly restore it.
Not trying to be a smart-you-know-what here. But in all honesty, my feelings on "what is it worth" are similar enough to Steve Adams' thoughts on this subject that I usually refer those looking for values to this page on his website. (Steve owns the Radio Attic.)
Good luck on that 41-250. You're going to need it.
Thanks Ron,
Looks like a nice challenge.
I have been replacing the wires one by one
Where do you get the heat shrink? Antique Electronic Supply?
Thanks
I get my heat shrink locally, at the only remaining electronics distributor in Evansville (Hutch & Son), in five foot lengths. It comes in clear, white, yellow, red, green, blue, and black. I do not buy the clear, but I get the other colors. When slipped over the wires and shrunk, it looks very authentic.
You can probably buy it online from one of the distributors such as Mouser, Allied, and/or Digi-Key.
Here is a short spiel relating my experiences restoring a 41-255.
http://home.comcast.net/~suptjud/philco41255.htm
Ron pretty much covered it all. If you have difficulty aligning the push buttons try replacing the 370pf mica cap numbered 21 and 21B in the Rider schematic. It is a dual cap and I am not sure it really is a mica cap. I have found them bad in a couple of radios of this design and vintage.
Like Ron said, it is a LOT of work but a nice radio when working properly.
Kind regards,
"Life is simpler when you plow around the stump."
Very nice transformation on the 41-255 Terry! I have a table model 38-7 that is missing a few pieces of veneer on the front. Is working with the paper thin veneer relatively easy? I've yet to attempt to do anything with this cabinet nor done any veneer work. Seems to me that with the paper thin product matching and cutting the patch would be simpler.
I have used the thin veneer on several radio cabinets and had good results. It may have been dumb luck. Icon_smile Where I needed thicker veneer to match existing veneer I just glued on extra layers.
Kind regards,
Terry does GREAT work on those vintage radios, doesn't he? Icon_biggrin
Thank you, Terry, for pointing out that dual 370 pF cap connected across the bandswitch - that, too, will need to be replaced. The original is either mica or a very early ceramic affair, insulated only by a wax coating that breaks down over the decades. It is two 370 pF capacitors in one package; one wire is common to both units.
Terry, in my experience, nearly every one of those units has been bad and required replacement.
It needs to be replaced with two separate 370 pF mica capacitors - if you cannot find 370 pF, 390 pF will work well.
Do not use ceramic disc caps to replace this unit - use silver mica. Ask me how I know this. Icon_rolleyes
Hi , I just wanted to comment on the original post. I am a novice but have done 4-5 prewar set with help for sites like this . If you have a digital
camera take a bunch of shots from all angles of the under side of the chasiss wiring . I find no matter what brand of radio I work on the one wire one side at a time does not always work. You get into areas (band switch or push buttons ) where it is easier to take off more than one end .
The digital photos have helped me every time . Kind of an obvious tip but
it is a time saver . Also my first set has been running for many years.
I did it pretty quickly . Now I take a little bit at a time approach ,and think it results in a better job for me. However you do it I am sure that the result will be worth it . Just wanted to mention the camera tip. Good Luck with it !
Bill T
Thanks Terry and Ron for that tip on the dual 370 pf capacitor. I saw "mica" on the parts list and was going to ignore it. I was just checking the chassis yesterday to order the capacitors, resistors, Etc. I need. At least the cabinet probably only needs some Howards finish restorer.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
Philco 42-390, code 121 speaker
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
There are currently 4562 online users. [Complete List]
» 1 Member(s) | 4561 Guest(s)
