Today's special
hi Brenda
not sure but pic 1 looks like counter balance
here are pic looks like yours is missing wedge that pushes merc switch
[Image: http://i1303.photobucket.com/albums/ag14...ac1d1b.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...03e2d2.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...eac61e.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...2e54d2.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...3d332e.jpg]
hope it helps
sam
Yes, that piece is definitely missing from mine. Does anyone make a repro, or do I need to machine one myself?
Also, what, then, is the purpose of the little free swinging bar?
hey Brenda
looks like turns on and off merc switch
sam
Cartridge was mailed off to West-Tech today. Don't know what the turn around is on that, but hope I can find any other missing parts soon.
I've gotten the service packet for the M-7 phono from Steve. In going over that information, I see some of the parts that I need. I need to find the "spring" (that "T" shaped part on the switch assembly) that activates the mercury switch. Note the difference between my pics and Sam's, this part on mine mounts with the holes at an angle on the mount.
Also, I need to know what thickness of rubber or whatever I need to glue back on to the tone arm actuator arm (the one that is supposed to move the pawl), because even with the little rubber dimple on the pawl, it doesn't come anywhere near the actuator arm. Also, the manual says that this pawl is supposed to contact the mercury switch assembly to turn the switch off at the end of record play, but I can't see where it can contact the assembly at all, let alone be able to turn off the mercury switch.
Everything else seems to be pretty well functional. The idler wheel is intact, the only issue with it is a very small indentation where the capstan had been in contact with it for a long time. It's enough to make a sound as it goes by the capstan, but doesn't seem to affect the platter speed. The rubber is still quite pliable, and I suspect that this small dimple will work its way out of the idler with time and use.
Brenda
I looked at mine they are the same 50Y6 and 35L6
I looked at turn table in your first pic circled when arm comes to center it push's counter balance enough to click player off
the three idlers are rubber caps you can slide them up and off on wood dowels
Arran, Thanks for digging into your radio library. The Studebaker radio model is AC-2687/S5524. It has a power/ speaker...Pdouglaski — 02:04 PM
Philco Battery-WWII vintage
Yep. It had handles on either side, and it took two reasonably strong men to carry it. We had that Soviet FIAT 500 c...morzh — 11:45 AM
PT-6 finished!!
I’ll get on doing that and see what happens. Just to keep this all in one thread - Anyone know what length/size is u...bridkarl — 10:01 AM
Hello Ed, Well done on your part anyway that radio uses neon bulbs ? Sincerely richardradiorich — 09:43 AM
PT-6 finished!!
I agree with Ron. That’s how my 49-906 behaves. That’s why I’m curious if the bulb stays at full brightness if the recti...jrblasde — 07:54 AM
I don’t know exactly how dim your pilot gets but this is the typical of the response of many transformerless AA5s where ...462ron — 07:38 AM
Well Philco did start out in the lead acid battery manufacturing business, and I think that they were still doing so dur...Arran — 12:06 AM
It is odd that they chose the autodyne mixer/oscillator in one version of this set, with the #15 tube, but chose to use ...Arran — 11:02 PM
Information on the Other Front Runners of the Era
It's not  philco but I use it quite often for Marconi radios which are Canadian. It is just another resource for u...Dan Walker — 10:25 PM
Glad to hear the radio is back home. David :clap:David — 08:47 PM
There are currently 914 online users. [Complete List]
» 1 Member(s) | 913 Guest(s)
