BK 700
I am looking at this tester and not sure if I can use it for the old tubes testing, 22,27, 42, 47, 80 etc. Know nothing about it, there is no rolling chart and the picture does not show correct sockets and numbers.
Is it suitable for my purpose? Thanks.
Here is a copy of the manual, if that helps.
http://www.k7jrl.com/pub/manuals/b&k/700/b&k_700.pdf ,
and more info links here,
http://www.18watt.com/forums/viewtopic.php?f=12&t=22157
Warren,
Thanks.
So, I've just found out, that the tester is not suitable for the antique tubes (less than 7 pins). Which mutual conductance tester make should I be looking for?
The most common good quality tester that is also the least expensive (sic) is the I-177. You see them fairly often on ebay. The best by consensus seems to be the TV-7. Both of these are excellent mil spec testers.
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
There are currently 504 online users. [Complete List]
» 1 Member(s) | 503 Guest(s)
