42-1008P Stain *Cabinet Done*
#31
So here is what I am wondering about.
[Image: http://i1289.photobucket.com/albums/b519...edp7bu.jpg]
I believe the unit had original finish on it so from what I can see the trim piece that comes up along side the door is dark like other dark areas (red oval) and then hits a transition or swirl into that flat side piece (orange circle) and then the flat side (blue circle) is just about as toned as the face.
Does that seem to be what I should be going after?
#32
Just when you think you have a section looking good the sun hits it just right and you see a bad sanding job Icon_sad
Going to move on and figure out if I want to worry about fixing it.
I'm not all that good at this wood stuff.
#33
(03-28-2015, 01:16 PM)Edisla Wrote:  Just when you think you have a section looking good the sun hits it just right and you see a bad sanding job Icon_sad
Edisla, don't give up. You have been working hard on it. Maybe just sand a little more with finer sand paper and it will look nice when covered with clear, etc. Icon_smile Don't forget to always sand WITH the grain.
#34
I wont give up.
I may give in a little but will not give up.
#35
Well here is how it came out.
Not exactly how I wanted it but it is close enough.
Before
[Image: http://i1289.photobucket.com/albums/b519...vxg1z2.jpg]
After
[Image: http://i1289.photobucket.com/albums/b519...cvak9q.jpg]
#36
Lookin Nice ...
#37
Yes it does look nice... Icon_thumbup Icon_thumbup
#38
looks fine to me great job Icon_clap Icon_thumbup
sam
Yesterday checked Mouser for the price on some caps and was curious about the mica equivalent. The 27pf 1kv ceramic is 2...RodB — 09:58 AM
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
There are currently 1185 online users. [Complete List]
» 2 Member(s) | 1183 Guest(s)
