How to match the original finish?
Threads: 20
City: Decatur Alabama
I bought a beautiful Philco 48-1263 last night. The finish is gorgeous except for the top, where of course someone placed a flower pot at some time in the past. The veneer is broken and strips are missing- no big deal, but how do I EXACTLY match the rest of the finish? What color?
Threads: 112
City: Medford OR (OR what?)
I take it you have little experience with vintage furnisher or radios?
In short, you should take it to a professional - or two, that do.
Threads: 574
Yep, good advice.
Threads: 337
City: lawrenceville nj
Not nice or helpful guys
We all have to learn some how
If I asked same question would you say same thing
Ps I may ask too as I don't know how to do cabinets
Threads: 574
Depends......I go to a pro myself (or at least I think he is).
Threads: 337
We'll I'm at the end of his line
Threads: 574
Me too! I am sure he has not even started on my stuff.  He is all about Halsons now. And hotel radios.
Threads: 20
Actually, there are only two things I ever tried to do that I didn't become very good at- sex and golf. Turns out, though, you don't have to be very good at either to have an immense amount of fun. I do have some experience in furniture refinishing, but I guess I should have asked "what is the specific color I should be trying to find?" There are two small photofinish strips on the top which I can duplicate rather easily, but I'd rather not have to strip the entire cabinet. It only needs the top done. And don't worry, I check my feelings at the door. If I hadn't wanted your honest opinion I wouldn't have asked.
Quote:"If you take in a starving dog and feed him and make him prosperous he will never bite you- this is the principle difference between dogs and men." Mark Twain
Threads: 0
City: Pocasset, MA
Quote:how do I EXACTLY match the rest of the finish?
You use sealer/filler and then spray toner and lacquer, the same as at the factory. The precise color of the toner, and whether translucent or opaque, "depends" (on a lot of things). Rattle cans of lacquer work fine.
Threads: 112
OK. You go out and buy a compressor, painting equipment, materials, if you can find somebody that will still sell you gallons of lacquer, dye, and so on. Then learn how to match or replace veneer after acquiring said veneer. Then you practice for about 2 years. And still you will probably not get it "Exactly" right.
You want to save some money? Do what I said.
And we have not even started on whether or not the radio is to work or remain working, but, I would say this part is slightly easier. Might not take two years, but for some it takes longer.
If you are asking about making a hobby out of it, never mind.
(This post was last modified: 05-15-2015, 11:52 PM by Phlogiston.)
Threads: 337
SOME TIMES SAYING NOTHING IS BETTER
sam
Threads: 112
(05-16-2015, 12:36 AM)sam Wrote: SOME TIMES SAYING NOTHING IS BETTER
sam
SONETIMES the truth hurts.
Russ
Threads: 310
City: Kings Park NY
1. The top sounds roached but a photos would be great.
2. If it is that bad I would either remove the top veneer or patch the existing veneer.
3. If this is not something you feel comfortable doing then let us help you as you post each step.
4 As for the plant stain, that may kill the repair idea. You would have to strip it with all good areas taped and papered off.
Then use a bix stripper of the like to softed the finish and scrape off with a plastic scraper being careful not to over apply so it seeps onto the new finish.
4. If the stain is white you can try stain to batch it. If it is black you can use wood bleach.
5. If the damage is on the curve which I suspect it is not you will still have to strip the whole area in the center.
6. Whe you are happy with the results then you can apply a sanding sealer and tone.
7. The toner is fairly easy to use in rattle cans. Just apply thin coats a few minutes apart until it is the desired color.
8. I would use medium walnut as it has that reddish hue to it.
9. Sand lightly using 200 sandpaper and go to 400.
10. Then you can clear the area with spray lacquer (clear) apply light at first them wet coats.
11. Sand between coats and when you are happy with the coverage, sand from 400 to 2000 Grit.
12. Let it cure for at least a month before finishing with pumice if desired and then use plain old jonsons butchers wax to shine that baby!
Post every question before you move on to each step.
If you need to Re-veneer you can use paper backed and titebond 2 glue. Apply to both the cabinet and the veneer, let dry and then Iron on the veneer. The stripes may cause you some grief but I have actually just toned the stripes on in some cases. Looks great and very hard to tell it is not inlaid.
Kirk
AC: 4 DC: 1
Threads: 337
kirk
thanks for info
a little help always go a long way
sam
Vlad;
Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM |
Rod;
I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM |
Rogers Majestic R-646
Vlad;
It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM |
Hi OSanders.
another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM |
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM |
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM |
Arron,
Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM |
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM |
Thx Vlad.klondike98 — 06:54 PM |
Hi Arran.
I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM |
