Model 65 Hiboy
Hi All
I am new to the group. I acquired a mod 65 highboy that I am trying to restore but it has some items in the chassis that do not match the Ryder schematic I have. I found a bad ant primary coil that I will rewind but this coil looks to have a center tap and a switch. The schematic shows a 5K resistor to gnd.
I was wondering if any of you experts would enlighten me if someone had run across this before
any help would be greatly appreciated.
Bob L.
Hi bob, welcome to the Phorum!!!  Icon_wave .
Moved your post to this new thread in Electronic Restoration.  It would disappear in the other section after awhile.
Hi Bob and Welcome,
Don't see a ct either on the ant coil. A tap and a switch could be used a a local/distance set up.
http://www.philcoradio.com/tech/images/65.jpg
This schematic shows a tap in the antenna coil primary and a local-distance switch, part (32).
(07-07-2015, 06:13 AM)Ron Ramirez Wrote:  http://www.philcoradio.com/tech/images/65.jpg
Thank you for the info and schematic one more question the location of the volume control I must be blind can't see it on the schematic.
i also have 2 more consoles and 2 table tops. Icon_biggrin
Thanks for the help
Bob L.
I believe its here:
[Image: https://dl.dropboxusercontent.com/u/5462...volume.jpg]
Bob,
Yes that is the volume control.
Bob L,
How it works is it varies the screen grid voltage on the two RF amp tubes. The lower the screen grid voltage the lower the gain of the tube hence the lower the volume and vise virsa.
Need Help to ID this radio 11 tube Philco
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
There are currently 297 online users. [Complete List]
» 2 Member(s) | 295 Guest(s)
