02-17-2010, 01:31 PM
That choke is supplying B+ to only one tube, the 227 detector. According to the Philco 87 and 65 service manual, this tube only draws a maximum of 3.5 mA in this circuit, so I feel that the Radio Daze replacement would be OK. The slightly lower resistance will cause the 227 plate voltage to be slightly higher, but it should not make a difference to the radio. If it bothers you, you could add a 300 ohm resistor in series with the choke.
