Mohawk Tone Lacquer & Sanding Sealer Steps???
Hi All,
1st time using the Mohawk Lacquer Toner, Sanding Sealers.
Philco 80Jr Radio.
Using Mohawk Ultra Classic Toner Ultra Medium Brown Walnut M100-0207 for front of radio.
Using Mohawk Ultra Classic Toner Ultra Perfect Brown M100-0249 for the sides, outer front, and bottom edge.
Read about as much as I can find on the net and forums.
Question does a coat of sanding sealer need to be applied between coats of the lacquer toner??
Here's the steps I think, is this correct?
1. Sand cabinet
2. Apply a coat of Mohawk Heavy Bodied Sanding Sealer M102-0491.
3. Lightly sand.
4. Apply a coat of Mohawk Heavy Bodied Sanding Sealer M102-0491.
5. Lightly sand.
6. Apply a light coat of Toner.
7. Apply light coat of Toner.
8. Lightly sand.
9. Apply wet coat of Toner.
10. Repeat till desired color darkness is achieved.
11. Lightly sand between coats.
12. Apply coats of Semi Gloss Tone Finish M102-0419.
13. Lightly sand between coats.
Does this look correct?
Also should Tone Finish Lacquer Sanding Sealer M102-0423 be applied over the toner?
If so, at what step #?
Thanks for your help
Mohawk Tone Lacquer & Sanding Sealer Steps??? - by Lewiss - 10-19-2018, 04:24 PM
