The engine is a B&S 23 inch cast Iron holds 2 quarts of oil. The Generator is a 4 pole 1800 rpm mine was made in 1952 was purchased in 1983 by a WW2 veteran who was a radioman. The generator was new Jack picked it up from a surplus store in Largo Florida. The design is from 1935-36 output is 120 volts using a twist lock connector. If you take a voltage reading from either pin to ground will read 60 volts AC pin to pin 120 volts AC. Old voltage standard from 1920 era. The house I grew up in had that set up so the fuse box had 2 sets of fuses for each circuit. When the panel was updated Tampa electric had to install a new transform for my parents house.
My Atwater Kent 84
There are currently 1952 online users. [Complete List]
» 3 Member(s) | 1949 Guest(s)
