02-21-2013, 06:25 PM
I decided to just tear right into this tabletop I picked up recently and hopefully get it done in a few days.
First up I unmounted the power transformer so I could strip the rust and repaint it. I also started removing rust from the chassis.
[Image: http://farm9.staticflickr.com/8366/84964...1e7a_c.jpg]
Next up, I restuffed the three section electrolytic, bakelite blocks and paper caps.
I used brown hot glue to plug up the cardboard tubes.
[Image: http://farm9.staticflickr.com/8505/84953...837a_c.jpg]
I carefully cut the can right about where the clamp goes and gutted it. The paper sleeve and clamp hold it back together very firmly .
[Image: http://farm9.staticflickr.com/8106/84953...031f_c.jpg]
Here it is after restuffing.
[Image: http://farm9.staticflickr.com/8238/84953...bf6a_c.jpg]
Both controls were frozen up more solid than any I've encountered before. Eventually, with the aid of some penetrating oil, rust dissolver and heat, I got the band switch working
The volume control/power switch wasn't quite so easy. I found evidence someone had pried it open and tinkered with it in the past and was ready to write it off as a lost cause. I kept at it though and finally got it working quite well, but in the process ruined the metal tension ring.
Here's the damaged control on the left and a good one. Any suggestions on replacing that ring ?
[Image: http://farm9.staticflickr.com/8519/84964...a2bd_c.jpg]
