116X Finish
No I wouldn't try lacquering over polyurethane, knowing the way things work the lacquer may not wrinkle but it may not stick to it either. A very thin coat of shellac maybe, but why take chances, if you can get sanding sealer use sanding sealer.
With regard to using mahogany as a patch, if it is actually mahogany the colour and grain structure will make it stand out if it's set into a stump/crotch walnut panel, unless of course you want it that way. The hole that was drilled was likely only 1/2 inch wide, and the grain was sort of straight in that area, so it shouldn't be too hard to find a piece of walnut that will blend in.
116X Finish - by Keith - 03-04-2013, 10:45 PM
RE: 116X Finish - by Arran - 03-05-2013, 03:24 AM
RE: 116X Finish - by Keith - 03-05-2013, 03:43 PM
RE: 116X Finish - by Ron Ramirez - 03-05-2013, 05:54 PM
RE: 116X Finish - by Phlogiston - 03-05-2013, 06:21 PM
RE: 116X Finish - by Arran - 03-05-2013, 08:03 PM
RE: 116X Finish - by Keith - 03-05-2013, 08:14 PM
RE: 116X Finish - by Phlogiston - 03-05-2013, 10:30 PM
RE: 116X Finish - by Ron Ramirez - 03-06-2013, 08:57 AM
RE: 116X Finish - by Phlogiston - 03-06-2013, 11:33 AM
RE: 116X Finish - by Chuck Schwark - 03-06-2013, 04:10 PM
RE: 116X Finish - by Ron Ramirez - 03-07-2013, 05:26 PM
RE: 116X Finish - by Phlogiston - 03-08-2013, 01:42 AM
RE: 116X Finish - by Phlogiston - 03-08-2013, 01:51 AM
RE: 116X Finish - by Keith - 03-14-2013, 03:37 PM
RE: 116X Finish - by Keith - 03-14-2013, 03:54 PM
RE: 116X Finish - by Phlogiston - 03-14-2013, 04:28 PM
RE: 116X Finish - by Arran - 03-14-2013, 06:47 PM
RE: 116X Finish - by Keith - 03-22-2013, 04:29 PM
RE: 116X Finish - by Ron Ramirez - 03-22-2013, 04:46 PM
RE: 116X Finish - by Keith - 03-22-2013, 08:25 PM
RE: 116X Finish - by Ron Ramirez - 03-22-2013, 08:38 PM
RE: 116X Finish - by Phlogiston - 03-22-2013, 09:12 PM
RE: 116X Finish - by Arran - 04-01-2013, 02:30 AM
There are currently 1759 online users. [Complete List]
» 1 Member(s) | 1758 Guest(s)
