12-23-2007, 09:59 AM
Hi , I just wanted to comment on the original post. I am a novice but have done 4-5 prewar set with help for sites like this . If you have a digital
camera take a bunch of shots from all angles of the under side of the chasiss wiring . I find no matter what brand of radio I work on the one wire one side at a time does not always work. You get into areas (band switch or push buttons ) where it is easier to take off more than one end .
The digital photos have helped me every time . Kind of an obvious tip but
it is a time saver . Also my first set has been running for many years.
I did it pretty quickly . Now I take a little bit at a time approach ,and think it results in a better job for me. However you do it I am sure that the result will be worth it . Just wanted to mention the camera tip. Good Luck with it !
Bill T
Bill T
