battery set info
The cap they're talking about would closer to 0.005 or so at as much as 1600V. The ones you're looking at are probably across the 6V input line for RFI.
Ah yes, When I removed the paper surround I found 3 more caps and one is .01 1000
but what does the .5 10 mean on the cap? what is the value?
Could well be a 10V cap if it's across the 6V input line.
That high voltage is available from Mark Oppat.
I did my 6 volt zenith farm radio, and that one ended up with a 1600 volt cap.
I also bought a 6 volt sealed battery on ebay for $10.00 with free shipping. They are rechargeable too.
Vibrator will need to have contacts cleaned or re-built.
Good luck.
murf
Arran. As always, the information you have provided is very valuable to me. Thank you. Yes, it is a Canadian Philco 316A...RadioSvit — 04:04 PM
Best to use the one from the library on this site, then when you refer to part 30 we know which part you are referring t...RodB — 03:32 PM
52-942
Welcome to the Phorum, Ken! The included schematic for your set is located in the Philco Library at the bottom of our Ho...GarySP — 03:13 PM
Video Source for Predicta
You can also source a used VCR and use that as a modulator to feed your DVD source into.TV MAN — 02:57 PM
52-942
Just received my 52-942. Its a handsome set. When I opened the back to examine it I noticed there are not connecting wir...Ken Arroyo — 02:54 PM
"Your radio tubes get these voltages from the power transformer secondary windings. The A voltage is supplied by th...osanders0311 — 01:40 PM
Please correct me if I am wrong, while working on this radio I noticed under the chassis where the bottom of the tubes p...osanders0311 — 01:28 PM
"BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you rep...osanders0311 — 01:04 PM
BTW there's a 2.2k resistor from B+ to one of the XXL tubes so you have to identify those resistors before you replace t...RodB — 11:08 AM
Okey dokey, let's get on the wayback machine. Back when radios were running on batteries, they were powered by three DC ...RodB — 10:34 AM
There are currently 837 online users. [Complete List]
» 1 Member(s) | 836 Guest(s)
