07-31-2016, 01:00 PM
looking good bob
Philco 50 (early version)
looking good bob
Some day, and that day may never come, I will call upon you to do a service for me. But until that day, accept this justice as a gift mafiamen2
08-16-2016, 04:02 PM
So...have been continuing the recap. An earlier repair did some more creative rewiring on block Cap #12 seen here:
[Image: https://www.dropbox.com/s/3m6h6b9nepffrg....jpg?raw=1] You can see lug #1 on the cap (closest to the nut) has been removed. The paper tubular cap seen in the picture is a replacement for the original block cap and would have been internal to the block between lugs 1 & 3. I did some creative repair of my own to put a new lug #1 in place and rewired the block cap to use lugs #2 & 3 for the internal cap and lug 1 for the tie point. [Image: https://www.dropbox.com/s/4rp6hmhea6o8cg....jpg?raw=1] In any event...it all went back together with new resistors as well. I just can not make those dogbones with the metal ends reproduce right so I just made the wire wrap style dogbones. [Image: https://www.dropbox.com/s/y585btyc7zce2q....jpg?raw=1]
08-16-2016, 04:52 PM
Next up is working on the rust on tuning cap and chassis. Taking the tuning cap off means also taking off the metal shields for the coils (I don’t think I mentioned it but the coils all seem to be good).
[Image: https://www.dropbox.com/s/hwcqep5jhp03xk....jpg?raw=1] I ground off the top of the 3 rivets with a Dremel tool and the shield came off nicely. This allows you to get to the 3 screw/lug connections and 2 soldered ground connections to the tuning cap. [Image: https://www.dropbox.com/s/k5a0ypueefkyt9....jpg?raw=1] Being somewhat klutzy, I put some plastic shields around the coils to protect them a bit from straying screw drivers and soldering irons. Yes, I managed to melt some plastic in the process. [Image: https://www.dropbox.com/s/xmb83ak9m3i7qc....jpg?raw=1] I took the dial off the tuning cap so I would be able to dunk the entire cap into the Metal Rescue de-rusting solution. We’ll see how it comes out.
08-16-2016, 07:14 PM
(08-16-2016, 04:52 PM)klondike98 Wrote: Next up is working on the rust on tuning cap and chassis. Taking the tuning cap off means also taking off the metal shields for the coils (I don’t think I mentioned it but the coils all seem to be good). Hey Bob, If you have a little to spare I could use a good soak too..... When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
08-16-2016, 10:10 PM
08-16-2016, 11:04 PM
08-17-2016, 04:38 PM
Well that's looking better, not perfect but better...
[Image: https://www.dropbox.com/s/da718t47nqe7a2....jpg?raw=1]
08-17-2016, 09:50 PM
08-18-2016, 05:09 AM
I didn't know that the tuning condensers in those model 50s were all steel? I didn't think that they could make those with ferrous metals in the plates, I thought that they had to be something like brass or aluminum?
Regards Arran
08-24-2016, 05:58 PM
A little more work on the 50. The tube shield got de-rusted and the lable on it was remade. The original was badly stained and at some point I manage to tear it. I was able to get it back together for a scan and then some clean up. Its not of the quality that Nathan is able to do but I'll post it in the download section in case someone needs it and and can't find a better one.
[Image: https://www.dropbox.com/s/hl5ngktcuf5g6b....jpg?raw=1] [Image: https://www.dropbox.com/s/jvxbbiva6mtnki....jpg?raw=1] With the rest of the chassis there was some cleanup, the tuner cap was reinstalled, the two electrolyics are reinstalled, new leads on the coils to the caps of the 24As, and new speaker wires. I had taken the tuner knob mechanism off thinking I needed to do that to get the dial off without drilling out the rivets but I wound up doing the drill out anyway (so I could dunk the tuner in Metal Rescue solution). It took a few tries to figure out the best way to get that mechanism back together. [Image: https://www.dropbox.com/s/njlika45iupd7k....jpg?raw=1]
08-27-2016, 03:50 PM
Anyone happen to know what pilot bulb goes in the the Philco 50? It doesn't happen to be listed on the Riders or Beitman pages. I "think" I see 2.5 volts on the existing bulb and its a screw in type so I think its a #41 based on the info on Chuck's pages. Thanks!
08-27-2016, 05:50 PM
(08-27-2016, 03:50 PM)klondike98 Wrote: Anyone happen to know what pilot bulb goes in the the Philco 50? It doesn't happen to be listed on the Riders or Beitman pages. I "think" I see 2.5 volts on the existing bulb and its a screw in type so I think its a #41 based on the info on Chuck's pages. Thanks! Yup! 41 is the one. When my pals were reading comic books I was down in the basement in my dad's workshop. Perusing his Sam's Photofoacts Vol 1-50 admiring the old set and trying to figure out what all those squiggly meant. Circa 1966 Now I think I've got it! Terry
08-27-2016, 06:54 PM
Thanks Terry
08-28-2016, 09:52 AM
I am always amazed when these rusty hulks get cleaned up, recapped, recarbed, repaired and actually come back to life
[Image: https://www.dropbox.com/s/c68cyh6271agtv....jpg?raw=1]
08-28-2016, 10:43 AM
Nice work.
« Next Oldest | Next Newest »
Users browsing this thread: 1 Guest(s) |
