Aria radio Schematics
Hi, I just found a small tabletop Aria Radio. I know that this radio name was made by several manufacturers prior to the war. It has model 543 hand written on the bottom of the cabinet but other than that no indications. I also spent 3 days looking on Nostalgia Air at all manufacturers for models 543. I found one close to the tube line up. My radio has 80, 6A7, 6K7, 6Q7G, and the last tube is missing which I suspect to be 6f6. The closest one I found was made by Stewart Warner, Its line up is 5w4G, 6a8G, 6k7, 6Q7G, 6F6G. Does anyone have any help here so I get off to the right start. This thing has such a cool wood cabinet in great shape.
By the way, my radio has what I believe to be the antenna coil on top of the chassis and not protected other than a wax coating and the wires from it run to the back of the chassis and are cut off there. Looking at the label that has the handwritten model number on it, it makes me wonder it this was not a experimental model.
It has to be posted in Other radios. This is a Philco thread.
Pic's ???
Sorry about the question. I thought that because it was a no name it could possibly be related to Philco. I didn't mean to violate the rules. As far as pics, I haven't figured out how to upload pics here. If someone can tell me how I will for future things related to Philco. Also, I will not continue this thread because I want to honor the forum. It has been a help to me.
Don't sweat it. You might read this about posting pictures.
http://philcoradio.com/phorum/showthread.php?tid=29
No worries Radio Hound, we simply moved the thread. Hope you find the schematic or at least get an ID.
Hello hound!
 Here is a link to a website that has a search engine by tubes.
This is what I found under the tubes you have. A 41 seems to be popular for the 5th tube.
http://www.grillecloth.com/sylvania/tube...ubmit&db=5
Here are some pics from another site. Icon_smile
http://www.radiomuseum.org/dsp_treffer.c...rt=&Page=2
Icon_smile
Well, Oldrestorer you helped me figure it out. It was the Sentinal 148A. What threw me off was the handwritten model number on the bottom. When I saw your chart I looked for those model numbers all over the chassis and found a tiny stamp in the chassis that had 148A (barely visible). When I looked this schematic up, it was a exact match. Thanks again.
Here is a look at the radio identified as a 148A
[Image: http://i1036.photobucket.com/albums/a446...xezmya.jpg]
[Image: http://i1036.photobucket.com/albums/a446...k5t4ev.jpg]
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM
Hello Ed, yes, I like letting projects run for few days to make sure they don't start acting up . Sincerely Richardradiorich — 01:03 PM
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM
Refinishing Ideas
Hi Doppelganger, After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM
Philco model #20
Hi Rick, One other thing regarding volume on this set.  Make sure that the tube shield is in place.  this is that la...MrFixr55 — 08:22 AM
Philco model #20
Hi Rick, The volume control on the Model 20 has 2 sections and does 2 seperate things: One part of the control, ...MrFixr55 — 10:30 PM
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM
Yes - better it happened on the repair bench than returning to the owner. The other question is - do I also dissect a...EdHolland — 09:08 PM
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM
There are currently 746 online users. [Complete List]
» 1 Member(s) | 745 Guest(s)
