37-650 fading performance
The 37-650 I have starts up fine and strong but fairly soon (5 min or less) starts to "fade out" to low volume. I have to turn the volume pot to almost max to get "normal volume".
If I touch or even get close to the grid cap of the 6K7 tube that attaches to the tuning cap I get full volume to return. I've swapped out the 6K7 tube but get the same results.
Any suggestions on where to start looking? Output tubes getting gassy as they heat up?
I doubt its the output tubes. If the volume returns when you touch the cap of the RF amp 6K7, then it probably not related to the output stage. Does the B+ power supply voltage change when the problem occurs? Gassy outputs would make the B+ voltage drop noticeably.
Sounds like it might be related to the AVC circuit which controls the negative DC bias voltage on the 6K7 grid. This AVC circuit is also connected to the 6A8 and the 6K7 IF amp, so I would also try replacing these with known good ones.
You can also check the resistors marked 7 and 34 on the schematic and see if they have increased significantly in resistance.
What's your oscillator voltage doing? Is it going down until you touch the grid cap?
(I am assuming it's not de-tuning itself...that is, turning the tuning knob does not bring back full volume.)
Rob
I had the same problem, happened to be the 75 tube.
Can be any tube, can be other reasons, but I would replace the tubes one by one.
(09-18-2017, 06:44 PM)robsradioactive Wrote:  What's your oscillator voltage doing? Is it going down until you touch the grid cap?
Rob
Actually. If I could stand there with my finger on the grid cap all day I'd have a perfect playing set. Icon_smile
(09-19-2017, 09:08 AM)Tgace459 Wrote:  Actually. If I could stand there with my finger on the grid cap all day I'd have a perfect playing set. Icon_smile
Might be worth it Icon_lol
Clip a gator wire from the grid cap to your long wire antenna and you can get your finger back! Icon_lol
heehee
Hmmm...AM was fading but AUX input was working fine. Now even the AUX is faded out to almost static.
I'm gonna have to pull the chassis and take a look.
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM
