Padded Feet for Philco 38-15
Ron,
1. I have a Philco 38-15 that has four padded feet. They look like a thumb tack and are just slightly bigger. On the underside is inscribed MATTATUCK WATERBURRY. Do you know if replacements are available?
2. I also need a back for a Philco 40-124. And the correct grill cloth pattern.
Thank you.
David G. Woodward
WildDog Wrote:1. I have a Philco 38-15 that has four padded feet. They look like a thumb tack and are just slightly bigger. On the underside is inscribed MATTATUCK WATERBURRY. Do you know if replacements are available?
If these are the same feet as Philco used on their cathedrals and tombstones (and I suspect they are), these are no longer being manufactured (as far as I know). Many cabinet refinishers, such as Barry Jones, use small circular stick-on felt pads instead which do a better job of protecting the furniture they sit on top of.
Quote:2. I also need a back for a Philco 40-124. And the correct grill cloth pattern.
Sorry, can't help you on the back. I suggest you put an ad in the Philco Wanted section.
As for the cloth, that particular pattern is not being reproduced. A similar pattern is #8 from Radio Grille Cloth Headquarters.
http://www.grillecloth.com/
The 40-124 in my site's Gallery does not have the correct cloth for this reason. The correct pattern may be seen on the 40-90CB:
http://www.philcoradio.com/gallery/1940a.htm#e
This type of glide is available. A little bulky, though.
http://www.floorsaverglide.com/catalog/i...p?cPath=27
http://www.allglides.com/feltpads.html
[Image: http://www.floorsaverglide.com/catalog/i...nailon.jpg]
I use a nail-on plastic type from McMaster-Carr.
[Image: http://www.mcmaster.com/catalog/116/gfx/...13tp2s.gif]
Thank you all for your help.
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
