City: Lexington, KY
Looks good Mike!
The first radio I restored was your radios predecessor, the 5-S-127. Long story, but it was given to me as a young teen by very good friends of our family, but didn't get restored until several years later when I was in the USAF. I was very impressed with its performance also and DX'd many shortwave and BC stations with it. I probably ought to pull it out, replace the belt, give it a polish, and freshen up cap/resistors one of these days.
[Image: https://i.imgur.com/RYnUjR8.jpg?2]
Threads: 573
John
Yes that is also a very good looking set and seems to be almost the same other than the grill.
The performance of it should be pretty much the same as my 6 tune count vs your 5 is achieved by splitting 6Q7 diode-triode tube into separate 6H6 and 6F5 diodes and triode. Same output and likely the same speaker.
morzh Wrote:Ron
I meant removal of the other photo
This one is 90 degrees...
I did remove the photo that was turned 90 degrees. The one which remains was, and is, straight. On my end anyway.
Probably your tablet
Threads: 573
Probably.
To err is human. To really foul things up you need a computer.
(Paul Ehrlich).
Threads: 0
City: Manasquan
I have the same model radio (Zenith 6S229), purchased the exact same way (last minute impulse while leaving Kutztown -- exactly five years later than OP), with the exact same problem. I have never replaced or repaired a band, on a Zenith or any other vintage radio; could you explain the process in greater detail? the radio works fine otherwise, and I can even tune it by reaching inside and moving the bread slicer manually (I know, bad idea -- but it works).
Thanks.
Threads: 573
If by the band you mean the driving belt, I honestly do not remember, this was over 5 years ago, b ut every time I had to do it, it is so self-explanatory that I did not bother to look for instructions or to try to document it. Kinda like changing a bicycle chain. Two pulleys, the belt goes on that's it.
Threads: 0
City: Manasquan
Thanks, morzh; I was never any good at changing bicycle chains as a kid — we’ll see if I have improved with age! thanks for the assist
Threads: 573
Just pull the chassis and look at where the belt goes; it will be pretty much self-evident.
You will, I think, have to remove the dial assembly to change it.
Some info from Beitmans says late production. David David — 06:06 PM |
Restoring Philco 96
Oh wow! Just found this thread. Brings me back to early days on this phorum. I did a 96 back in 2017. Thread here:
...rfeenstra — 06:05 PM |
Thanks for the replies. It's not the really the hum that I am after. Just trying to understand why only the shortwave ba...Tubester — 04:01 PM |
Restoring Philco 96
70 and 90 are Superhets, but at least the 2x45 model of 90 uses the Plate detector (and so does 70).
Also the Atwaters,...morzh — 03:28 PM |
Restoring Philco 96
Morzh, Prayers for your mom. I am sure that there was enough pain living through the Holocaust as a child. I pray dail...MrFixr55 — 02:19 PM |
Hi Dan,
Divide and conquer. First off trry to differentiate between 60Hz and 120 Hz hum. 120 Hz hum has a higher pit...MrFixr55 — 01:49 PM |
Restoring Philco 96
Yes, other than takin a toll on your back, they are undeed way more repair friendly than many other Philcos.
To me, som...morzh — 01:04 PM |
If the wires look like they were this way from the factory (very neat and very dull soldering joints), I'd leave them be...morzh — 12:58 PM |
My Philco 37-116 Restore
I managed to open up the Expander Unit and replace the grid cap wires. Tested the connections found they looked good and...dconant — 12:19 PM |
610B Oscillator Questions
I've included a picture of the 'actual' schematic I created. I double checked several times and it appears to be accur...Tubester — 09:26 AM |
There are currently 2813 online users. [Complete List] » 4 Member(s) | 2809 Guest(s)
