Threads: 2
City: Boca Raton
Does anyone currently make a label set for the Philco Model 70?
I understand the ones sold on Ebay a few years back were not very good.
I saw a old post about Chuck Paci making these but when I sent an email to cpaci1@verizon.net it came back as undeliverable.
Has anyone found a source currently producing these?
Ron
Threads: 216
City: Seattle
State, Province, Country: WA
Hi Ron,
It should be possible to create a label set from the Philco 370 chairside labels:
https://philcoradio.com/library/index.ph...ls/page/2/
The tube layout label is already correct. It should be possible to update the model label.
I'll do that and add to the library.
-Nathan
Threads: 2
City: Boca Raton
Chuck Paci makes labels
Threads: 216
City: Seattle
Hi Ron,
Here's the patent label for model 70:
https://philcoradio.com/library/index.ph...ent-label/
Tube layout label:
https://philcoradio.com/library/index.ph...out-label/
See my thread on the model 370 labels for how to print it:
https://philcoradio.com/phorum/showthread.php?tid=14861
Do you have access to a laser printer? If not, PM me.
Good luck on the restoration!
Threads: 2
City: Boca Raton
Thank you Nathan. Yes I have a laser printer. Can you suggest a place to buy gold foil paper to print the label?
Threads: 216
City: Seattle
Oh sorry I thought it was mentioned in that original thread on the 370 labels. It's not.
The thread on 112 labels has it:
https://philcoradio.com/phorum/showthread.php?tid=17974
I bought gold paper from here:
https://www.paperpapers.com/stardream-me...k-dfs.html
Threads: 2
City: Boca Raton
Thanks Nathan the gold label looks fantastic. Anxious to make mine.
Thanks again.
Ron
Threads: 2
City: Boca Raton
I have this Philco Design Patent label on the arch of my Philco 70.
Is this available on the library? I would like to reproduce this for my other Philco cabinets.
Image(s)
Threads: 216
City: Seattle
Hi Ron,
No we don't have have that one yet. I've tried previously to recreate it but the result hasn't been satisfactory due to the lack of a good original scan or photo.
Do you have access to a flatbed scanner where you could scan what you have at 600dpi or higher? I'd be very happy to clean it up in Photoshop and add it to the Library.
A photo would be fine too if it's clear enough to read the small text under the Philco logo. To use a photo I'd also need the original dimensions.
Threads: 2
City: Boca Raton
I scanned my label with a flat bed scanner.
Size looks to be 1.75 by 1 inch.
Threads: 2
City: Boca Raton
Took another digital photo.
Image(s)
Threads: 216
City: Seattle
Thanks Ron!
For some reason the scan was at pretty low resolution. Generally scanner software will let you preview then select just a small area that you can scan at higher resolution.
The new photo is better. I'll give it a try with that.
Threads: 2
City: Boca Raton
Thank you. You are a great help to this hobby.
Threads: 216
City: Seattle
A Philco 70 / 90 design patent label is now available in the Philco Library:
Here are some photos of the end product printed on the same gold paper as the model label:
Hello Roy,
sincerely Richardradiorich — 12:45 AM
Richard,
Had grabbed it already but thank you just the same. I find myself wanting to find some way to block out the...glyphmon — 12:03 AM
Hello roy,
Sincerely Richardradiorich — 11:54 PM
Richard,
The Silvertone 2014 also is a transformerless set, so I am incorporating a 1:1 600 ohm audio isolation transfo...glyphmon — 11:37 PM
Did an alignment today which was interesting. IF alignment went great, almost all was already spot-on. Adjusting on th...glyphmon — 11:35 PM
While I'm waiting to wrap up the final steps on my wife's Silvertone 2014, I started disassembly on the next project. O...glyphmon — 11:07 PM
Hello roy,
Sincerely Richardradiorich — 10:50 PM
Safety caps arrived today. Soldered one in and had a successful first power-up. No magic smoke escaped and it tunes in...glyphmon — 09:53 PM
There are currently 1557 online users. [Complete List ]» 1 Member(s) | 1556 Guest(s)
