Threads: 51
City: Shenandoah,
Hi all, I’ve seen notes on service info concerning the 70 that there’s a difference between serial# B22,000 or above or below. I’m just starting on my 70 and the only number I see stamped on the rear apron of the chassis is 556792, no B in front of it so what exactly do I have? Thanks.
Ron
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 269
If it has a dual gang volume control it's the early model.
Threads: 51
City: Shenandoah,
Thanks Terry, early version is what I got then!
Ron
AK 35 Philco 46-350
Threads: 51
City: Shenandoah,
So in testing the tubes and general cleanup of my 70, I have discovered a little history behind my radio. I’ve seen 4 or 5 station call letters printed in pencil on the dial scale. Turns out they were all Detroit area stations. Then I find this sticker on one-off my 24 tubes. It’s from some shop in Detroit also. There’s what I presume is the set owners name printed on the back arch support! I wonder about how it made its way to me from Detroit to the Kutztown swap meet 4-1/2 years ago?
On another topic. What are you guys using for grille cloth? Looks like Richmond Designs is gone and I only find generic cloth on eBay! Thanks.
AK 35 Philco 46-350
(This post was last modified: 02-24-2021, 03:57 PM by 462ron.)
Threads: 7
City: bloomfield, ct
Have you tried this URL for Richmond ?
https://www.richmonddesignsinc.com/
He also sells on Ebay.
Threads: 7
AH, I see that the Home Page for Richmond designs is not operative.
Threads: 269
Maybe:
https://richmonddesignsinc.com/grille_cl...nd_24_x_24
But there isn't a good replacement for the 70/90 grille cloth.
Threads: 51
City: Shenandoah,
Ah there it is. Thanks guys. I don’t know why I couldn’t find Richmond designs. When I googled it and clicked, it came up 404! I’m a ways off yet from needing the grille cloth but will contact Richmond! Now onto cleaning up my dirty and slightly rusted chassis and electronic resto!
Ron
AK 35 Philco 46-350
Threads: 269
Have a look here and see if anything strikes your fancy. SPEAKER-FABRIC-SUPPLY | eBay Stores
Don't have my glasses on so can't see what they look like
Threads: 51
City: Shenandoah,
Thanks Terry, looks to be a few possibilities there!
Ron
AK 35 Philco 46-350
Threads: 71
City: Linn Creek, MO
Richmond Designs "Whiskey Rayon" is the one you need.
M R Radios C M Tubes
Threads: 51
City: Shenandoah,
Thanks Steve, that pin points it for me!
EDIT: Just ordered it, thanks again!
Ron
AK 35 Philco 46-350
(This post was last modified: 02-25-2021, 12:15 PM by 462ron.)
Threads: 51
City: Shenandoah,
Hi All, putting the dial back on my 70 and when the tuning gang is completely meshed, I can set the dial to read 55 but when I fully open it, I’m about a half inch beyond the 150 or high end of the dial. Can’t find anything in the Philco Library or Nostalgia Air as far as setting the dial before doing an alignment. Anyone have that info or should I just set my dial to split the difference between the low and high end of the dial. In other words, set it about a 1/4” below the 55 and that will give me a 1/4” above the 150 on the high end! Thanks.
Ron
AK 35 Philco 46-350
Threads: 49
City: Allendale, MI
both of my 70's and my 71 are set the same way. Just barely below 55 but way beyond 1500.
Threads: 51
City: Shenandoah,
Ok thanks Rob!
Ron
AK 35 Philco 46-350
Hi, there's a lot to consider when designing these circuits so you shouldn't have a lot of concern when replacing caps. ...RodB — 02:03 PM |
I have ordered and received new caps for this radio and hope I've ordered the correct ones. I tried matching them to the...osanders0311 — 11:35 AM |
Hello Jeff ,
Far as the Electrolytic capacitors go here is a list of parts.
that will work . I like using Nichicon and...radiorich — 09:50 PM |
Well, I've been stumped at trying to get the first of 11 electrolytic capacitors. I got a schematic and have a list of t...Jeffcon — 07:54 PM |
Thanks Gary and Rod.
I also found an article in the Philco Repair Bench under Service Hints and Tips, about installi...Hamilton — 12:32 PM |
Hello Hamilton, here is a little information found in our Philco Radio Library at the bottom of the Home page. Hope it ...GarySP — 11:28 AM |
I did as you suggested and touching the middle of the volume control did nothing so the coil has to be rewound. Any idea...Hamilton — 10:19 AM |
This would be the second portable in the "other radios" forum where I have a similar one in my collection. I h...Arran — 12:41 AM |
Hi PittsburgTost.
The record changer looks like a Garrard or BSR (Likely Garrard). The spindles just pull out and pu...MrFixr55 — 11:57 PM |
Hello PittsburghToast ,
There are currently 503 online users. [Complete List] » 3 Member(s) | 500 Guest(s)
