Studebaker Philco S4627
Hi everyone, I have just got this model of Philco car radio. I have got the schematic from Radiomuseum but I am wondering if there is any more info on this set available. Riders for 1949 does not list it under "Studebaker" and I don't know what the Philco model number is . Can any one help? Thanks all.
Try this link:
http://www.nostalgiaair.org/Resources/210/M0014210.htm
Seems to have a lot of information.
With push/pull output people down the street will hear you coming.
Played around with a somewhat later Philco /Studebaker from the 1950s, the thing had fantastic sound for an AM radio. One of the best
Looking at Beitmans for 1949 list 3 auto radios from Philco the one not shown was for Chrysler         . Hope this info helps. David
Thank you both for replying.I have printed off all the info there - what I was looking for and most helpful.I picked up the Studebaker set along with a Midwest Chassis 7 - 36 at our local vintage car swap meet ,reputed to be the biggest in the Southern Hemisphere, yesterday.Tho' a certain person located domestically insists today I can only listen to one radio at a time.
Hi Antipodal,
Listen to one at a time? Fire 'em all up at one time and impress the domestically located person (Oops, maybe that person may not come non-domestic! Ms. Fixr is not impressed with my hobby.)
I am a Tech Support Specialist for a BioMedical company (hopefully retiring after 40 years with them) and sometimes receive calls from Australia and New Zealand. Amazing to talk to someone on the almost exact opposite "side" of the world!!
Hi everyone,Thank you for your help - it is invaluable. I have the schematic and the other info too,now.Great!
The power supply is now active once some electrolytics had been replaced and the vibrator even got going reliably.Both 7C5s are going tho' at this stage not balanced. So, work to do.
My set lacks the foam rubber circle round the speaker on the outside which I presume seals the speaker against the grille in the dash. Are these available , or has anyone fabricated one, and if so, how?Thanks everyone and cheers.And enjoy that retirement , Mr Fixit- after 40 years you've earned it!
You will probably be better off cutting out your own from a sheet of Styrofoam, depending on the thickness.
This radio now goes. And, boy , does it go well! Now I'm working my way through the paper caps -check the radio goes, turn it off, replace one cap,turn it on,check it goes,replace next cap ...and so on. Tho' at this stage the permeability tuner is stuck in one place,fortunately on a good local station. More work to do there.
Yes, and don't forget to tune the antenna pad when you reinstall it in the car. Unless, of course, you are lucky enough to have the antenna on the bench. Don't ask how many times I forgot to do it. But I was limber enough to get to it.
I would recommend using closed-cell furniture foam seat material for the circle around the speaker. Styrofoam is too rigid, and prone to "squeaking" rubbing against other components. Spray adhesive can be used to adhere it to the speaker frame, or the cabinet depending how it was originally installed. Take care and BE HEALTHY! Gary
Thanks, Gary. I now know what to ask for at our local upholstery shop. Great!
I believe what they are talking about is called "backer rod" they sell it in hardware stores, and home centers, to fill large gaps, such as in a brick wall, so that the mortar doesn't get pushed out the other side.
Peter; Are you certain you wouldn't like the Deforest Crosley instead? It's probably the most "Canadian" of...Arran — 08:14 PM
What is this?
It would not be the first time someone among us misidentified a part. I can remember working on a Sonora AC/DC set where...Arran — 08:04 PM
What is this?
I restored the original post. It may be useful to someone in the future.klondike98 — 02:26 PM
Michael, this is one of the five radio consoles from Canada from my companion that I received for restoration and that I...RadioSvit — 10:16 AM
What is this?
What is this?
What is this?
What is this?
What is this?
I was starting to replace the paper capacitors in my Philco 46-1213 today.  My first piece I think I made a mistake.  I ...MissouriLarry — 11:05 AM
There are currently 1312 online users. [Complete List]
» 4 Member(s) | 1308 Guest(s)
AvatarAvatarAvatarAvatar
