Philco Model 84 - Bad Transformer?
I have a Model 84 and I think the transformer bad ... I going to check the current as suggested, but if it is bad (and I really think it is) what are my options?
Does anyone sell new, used or re-wired transformers for old radios? How much $$$ do you think it's going to cost? How hard is it to re-wire myself, and is any on-line help or information on the topic?
Thanks
Brian
Hi Brian and welcome to the Phorum
It's probably best to start a new topic (thread) for your question as it could be easily confused with the current one. Happy to answer your question there.
I split the two posts above from the original topic. Since this is a question about a different model, it does need to be in its own separate topic. Now it is Icon_smile
Tnx Ron and Happy T Day!
So Brian,
Why do you think the power transformer is bad?
Hi,
The Transformer run very hot, and starts to boil (bubbling sound) at about ~35V.
I haven't had a chance to check the current yet, but I've ohmed out the wiring, and I didn't find any shorts.
Brian
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 1022 online users. [Complete List]
» 1 Member(s) | 1021 Guest(s)
