Threads: 9
I'm still working on my philco 40-180 and need to replace the speaker. How do I know what kind of speaker to look for? Does it have a model number or does the schematic specify? Cany anyone suggest a reputable parts dealer for such a piece?
Ryan
Threads: 22
City: Acworth
State, Province, Country: GA
Ryan
I'm in the same boat. Looking for a speaker for a 41-245. Previous owner replace original speaker with a PM one. I heard this is the place to go for used parts http://www.oldradioparts.com/ . A schematic usually lists part numbers but they will be philco numbers. Don't know if that will help finding a replacement but I'd include all info you have in the request.
Cheers and good luck....
Danny
Ryan
I see the speaker you need was originally 12 inches in diameter, with an 1100 ohm field coil and 5.1 ohm voice coil. The speaker from a 41-280 is an exact replacement, as are speakers from Models 42-380 and 42-390. In fact, probably any 1940-42 12 inch Philco speaker would work.
These type of chassis and speakers are on eBay all the time. There are probably several collectors who have one or more of these in their basements. Perhaps a "Wanted" ad in the Phorum "Philco Wanted" section might help...?
Danny, your situation is different, since you are dealing with a table model set. You need a 5 inch speaker with a 1700 ohm field, 3.5 ohm voice coil. A quick glance through some Service Bulletins, cross-referenced against a 1946 Philco parts catalog, indicates that speakers from Models 40-130, 40-135, 41-230, 41-235, or 41-240 will serve as exact replacements.
Threads: 9
Thanks Ron. For future reference, how did you figure that out? Is it information I can find on the schematic?
Ryan
Yes, I found the speaker part number on the schematic for your set, and looked it up in Philco's 1946 parts catalog (Quick Selector Parts Directory). Then I looked up the part number of the speaker of a few other models from their schematics, compared them to the 1946 parts catalog, and that's how I came up with the cross-reference I gave you.
There is a 42-380 chassis and speaker on eBay right now, ending tonight.
http://cgi.ebay.com/220038159139
The speaker in this auction is the speaker you need. If the knobs are in good shape, you could sell them to Bill T for his 1946 radio-phonograph? Sell the chassis to someone else? Who knows. But this is but one example, the 40-180, 41-280 and 42-380 were some of the most popular Philcos in their time, so there are a lot of them floating around. And there are enough junkers of those types that you should have no problem finding a speaker.
Now if you only want a speaker, no chassis, one has just been posted.
http://cgi.ebay.com/280041092527
Threads: 22
City: Acworth
Mr. Philco
Thank you very much for the specifications on the needed speaker.
Danny
Threads: 9
Ron,
Do you think this speaker http://cgi.ebay.com/200052264055 would work for my 40-180?
Ryan
KC0PWA
Yes, it will. According to my 1946 parts catalog, it should be the right size and correct field coil resistance.
Greetings Phorum members,
Hope you can help me identify this type of wire in the photo I have attached. I am not sure ...georgetownjohn — 01:53 PM |
Philco 60 Squealing
All correct shields must be in place, all tubes correct no subs of any kind.
Check any soldered, riveted ground conne...Chas — 01:24 PM |
Philco 60 Squealing
I have recapped and replaced out of tolerance resistors and so on. Radio plays nicely on fairly strong stations. The pro...dconant — 10:55 AM |
Welcome Eric,
I agree with Bob and far as the two main electrolytic filter capacitors did you change them yourself or w...radiorich — 11:43 PM |
You mentioned the Philco manual and going through the check points...just to be sure we're on the same page here's the m...klondike98 — 08:13 PM |
Philco 42-1008 conversion kit
Interesting. I haven't seen that before.klondike98 — 07:02 PM |
12' Philco
Yes I had looked for it on the web as well some time back and could not find it. I was glad to see it turned up in Ron'...klondike98 — 06:59 PM |
Shadow Meter Bulb
Now if you had a set with a tuning light then the bulb type is important to the circuit, some sets used those prior to t...Arran — 04:58 PM |
Shadow Meter Bulb
Ok. Thanks for the correction.RossH — 03:09 PM |
Model 28L
For 28 you will probably need to buy a Hammond 125CSE. Or any of the series of the power you need, with SE suffix. Then ...morzh — 02:09 PM |
There are currently 6162 online users. [Complete List] » 1 Member(s) | 6161 Guest(s)
