Decals
I put a new "Philco" decal from Radiodaze.com on a Bakelite cabinet. How do I protect it without spraying lacquer on the whole thing? Can I put a coat of wax over it?
Eric
Eric
The Villages, FL
order a spare decal Icon_smile
I doubt wax would help much but it couldn't hurt. Maybe a mask and a spritz of lacquer and then steel-wooling the overspray would help?
Now that the radio is in a collector environment rather than a daily appliance the decal should hold up longer than the original.
Thanks, I'll give it a try.
Eric
The Villages, FL
Agree. Devcals for plastic or bakelite cabinets were more robust than those who would be covered by a couple of coats of lacquer. So, as my esteemed Exray colleague has suggested, mask off, and give it a shot or two of reinforecment lacquer, peel away really carefully and leave it be. If you screw it up, for sure you can repeat, but I hope not. Else keep you hand on the knob, not the cabinet.
Thanks Guys. It worked great.
Eric
The Villages, FL
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
Philco 16B Parts
Hi Dan, Mike is correct, there's a lot of painted stuff on the chassis but it looks pretty good. The sm is all there,sp...Radioroslyn — 03:50 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A...captainclock1988 — 03:43 PM
Philco 42-390, code 121 speaker
Using a 5W  1.5k  ceramic resistor in place of the field coil and using a 4 ohm PM speaker, I was able to bring the radi...Stevelog — 02:57 PM
Philco 60 Squealing
I have taken out the 2nd IF and found a problem or not. I believe the coils are litz wire. There is a very small strand ...dconant — 02:13 PM
Philco 6K7
I am restoring a Philco 37-60. The am reception is very good, but the shortwave is very weak. Run 6 Philco removes the g...bobbyd1200 — 01:35 PM
Hi Cap'n Clock, Unfortunately, I do not have this radio.  This is a shame because this should be a good performer.  2A5...MrFixr55 — 06:48 AM
I think it would come under either American Bosch or United American Bosch. American Bosch made sets for the American We...Arran — 05:53 AM
There are currently 5763 online users. [Complete List]
» 1 Member(s) | 5762 Guest(s)
