Lamp for Philco 46-427
The schematic for this set calls for a I100 bulb for the panel light. It is a bayonet type but not a 44 or 47 6 volt bulb. Anyone knowe what it is? Thanks - Joe jdgatto@earthlink.net
Joe,
P/N 34-2068 is supposed to be a type 47 bulb:
http://www.philcorepairbench.com/lamps.htm
Carl
Northern Panhandle, WV
Thanks Carl. I see my mistake now. When I first tried a 47 it blew out immediately, probably a fluke. I then went to a 44 but that draws too much current. Will go to radio shack and pick up another 47 and try again. Joe
I100 is the schematic/parts listing designator - Indicator (lamps) 100.
Just like L for coils, T for transformers, C for caps, etc......
Chuck
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 963 online users. [Complete List]
» 1 Member(s) | 962 Guest(s)
