Block cap Doc for 8035-C
Hi All;
I have the Block cap 8035-C and I cannot find it in the Block cap Documentation.. I find 8035-EU, ODG, ODU, SG, SU.. But, not --C..
THANK YOU Marty
Marty,
A Google search turned up this info:
http://philcoradio.com/phorum//showthread.php?tid=3890
Carl
Northern Panhandle, WV
Marty, see the Philco Bakelite Condenser Data sheet available on Philco Radio tech section: http://www.philcoradio.com/tech/images/bakelite.pdf
If you look down on the second page you'll see that the 8035-C was discontinued and replaced with 8035-ODG. Then you can look up the 8035-ODG values and lug placement on the first page.
Hi All;
Thank You Klondike, I see that now, for some reason I did not see page two.. and thought it only had a single page.. Now I can dig out the can..
THANK YOU Marty
Just a word of caution. I had recapped a Model 80 that had a bakelite block # that had been discontinued so I wired it like the replacement was supposed to be wired according to the datasheet. When I got no sound and started tracing the circuit to find if I had wired something incorrectly I noticed that the radio schematic indicated the bakelite block had to be wired differently than the data sheet indicated. I don't know if that was done at the factory or some subsequent repair but I'll now double check the schematic and the data sheet to be sure.
There are currently 1957 online users. [Complete List]
» 1 Member(s) | 1956 Guest(s)
