Question on Philco 6v car radio
Good day all, I am trying to locate information on what I believe to be an early 1950's am 6v car radio. I have located the model numbers, so I think, but have been unable to locate any schematics or manuals of this device. What is on the label inside the radion body is the following; P-5106 D-5107 C-5109 C-5110 C5111 C-5112 and then PART NO-78-0209. Browsing through this web site, these numbers appear to led to nothing even close to the radio itself. I could post a picture if that helps.
Thanks
Here are several pictures of the radio if this helps.
Thanks
That looks like a 1949 or 1950 Chrysler, Dodge, or Plymouth radio. I think I have a similar one around somewhere. The P-5106 etc. numbers are probably the Chrysler Corp. (Mopar) model numbers for the radio.
P prefix is Packard.
See here as a reference: http://philcoradio.com/autorad/autorad.htm
Chuck
These radios were the same electrically, the differences were in the mechanical fit and the cosmetics. The model numbers you listed are the Philco model numbers, the Chrysler/Mopar numbers were 3 digit in the 800 series; P-5106=812, D-5107=813 etc. After 1950 the 'P' prefix indicates Plymouth not Packard as Packard Went to Delco radios during 1950. In the postwar models the first two digits indicate the model year, 51=1951 there were no 52 Chrysler models as the 51's were carried over into 1952 with no changes. Hope this helps you out.
BTW, that part number on the label is for the label!
This is a 1951 Plymouth Mopar 812
What kind of meter is it? Relative to what is the voltage being measured? Are the AC line filter caps C53A/B hooked up...morzh — 10:47 AM
Hi, what I'm seeing on the schematic is one wire from the output transformer goes to B+ and the other goes to the 7B5 pl...RodB — 10:42 AM
schematics
The Philco Library is great for Philcos.  Great source of info. Philco Libraryslford310 — 09:59 AM
schematics
Hello MSENO, Welcome to the Philco forum and here is the schematic for that Philco! 41-290 Sincerely Richardradiorich — 09:48 AM
I double checked everything around the filter caps and it all seems to be hooked up right... Here are the voltage on ...sq65 — 09:45 AM
schematics
I'm looking for a readable schematic for a 41 290. can anyone help?mseno — 09:33 AM
Rogers Majestic R-646
Since the original schematic was in an old unreadable style, I created a new schematic diagram. Owners of this radio ca...Vlad95 — 11:09 PM
Hello Peter, What great project I am looking forward to see your progress with this console !! Sincerely Richardradiorich — 10:20 PM
Ok guys, JustRadios has me worried after reading an article about purchasing resistors and I hope that I haven't made a ...osanders0311 — 08:59 PM
Yeah, I have no idea what's going on there. I will re-check it in the morning, and also trace out the B+...sq65 — 07:55 PM
There are currently 1592 online users. [Complete List]
» 1 Member(s) | 1591 Guest(s)
