Gift from FIL. sweet
A little OT but I know there is a model 66 in the MB cabinet yet it is listed that there is only a 60MB. Is the 66 a MB??
Nope, the 66 in that cabinet was sold as a 66B. The 66B soon became a cathedral:
http://www.philcoradio.com/gallery/1935b.htm#e
I suspect this was Philco's way of using up excess 60MB cabinets.
Welcome to the Phorum.
For now, you can look up the data sheets for the tubes and check continuity on the filaments.
However, before you get wrapped around the axle with tubes (which are probably good anyway) start replacing all of the capacitors and any resistors that are out of spec.
Keith great looking radio. Good luck with it , go slow and have fun doing it....And most of all welcome to the forum!
If you want to do a quick test on the tubes pull out the 80 tube. Plug the set in and snap it on. Look at the tops of the tubes and you should see a small orange glow if the heater is OK. Do not do this with the 80 installed. You can damage the set if you haven't replaced the caps in it. As for the 80 tube use an ohm meter across the two fat pins on the bottom of the tube. Should show a very low resistance across these two pins. If not tube is bad.
Just want to call to your attention all the great advice from some great folks here on the Phorum.
You meet the best people here, it's almost like family, from Ron on down.
BTW, Ron is a PhD. (Doctor of Philcology)Icon_thumbupIcon_thumbupIcon_thumbup
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 600 online users. [Complete List]
» 2 Member(s) | 598 Guest(s)
