Philco 46-1203
It doesn't matter. If the value is small and you can omit using electrolytics, do so - electrolytic caps are a limited life part.
But if you do use them, observe the polarity.
Thanks Skyscraper. The caps in question are 10MF and 40MF. Due to their higher value, would it be okay to use an electrolytic? Which would be better?
Here is the schematic and diagram: http://s270.photobucket.com/user/Colorad...ent&page=1
Those have to be electrolytics I think. I also think it is a doubling rectifier so the voltage ratings you use have to be about 350V. That is 250V DC will not be exceeded if the load is disconnected (hence the 350V rating to have margin) and normally it is lower (175/110V for 40uF and 10uF respectively) but this is if the load is OK.
So, use electrolytics 40uF and 10uF 350V.
Thanks to everyone for their assistance. The 60hz hum is now gone and the radio sounds pretty good for having the original (from what I can tell) speaker. Now on to the record player portion of the unit.
The cap with the wire wrapped around it is a crude LC circuit intended to make the chassis have a low impedance connection to the radio B- supply line at the IF or RF frequencies, but have the impedance be somewhat high at 60Hz. Radio could oscillate without it. You could carefully slide the coiled wire off the old cap, keeping the turns spacing the same, and putting the coil over a new cap.
[Image: http://www.philcoradio.com/phorum/attach...p?aid=2757]
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2318 online users. [Complete List]
» 3 Member(s) | 2315 Guest(s)
