Car Radio УРАЛ, Ural-Auto 2 FM/AM/LW/SW.
Nice little message: You are not authorized to view or download files (in Russian, of course). But yes, I can probably work out some sort of battery for it. Good you told me it runs at 9V.
OK, you don't have to view them - he pretty much downloaded the pics from the same link you have. There is that pic with the radio open.
http://www.rw6ase-dok1.narod.ru/f/ural_awto2_25.jpg
This one.
http://www.rw6ase.narod.ru/000/rprl_p1/ural_awto2.html
Well, this is the main page for that radio - it says right there
>>>При этом приёмник питается от блока питания
состоящего из 6 элементов 343. - At the same time the radio works from the power block containing 6 type 343 batteries. The "343" was the Soviet "D", 1.5 volt.
http://boatsurfer.files.wordpress.com/20...be-2-2.jpg
One more thing: from the sch it seems like what they do is this:
They feed the output audio amp from whatever voltage comes in, 12-15V from the car circuitry OR from 9V of the portable battery (BTW the sch now that I looked at it also says "9V").
Then they use parametric stabilizer made with KT315 transistor (a small orange dipped thingy) to make about 5V out of it (using a Si transistor and 5.6V KS156A zener makes it about 4.9V or so) and use it to feed the RF part.
This put together makes the radio suitable for anywhere from 7V (will lose some power in the audio) to 15V (did not analyze - don't know if the parts are sensitive to high voltage) power in.
Any reason for the 2nd copy of the thread?morzh — 10:22 PM
Sorry Murf, technical is what I do. OK, Unlike the Western Auto Tru-Tones, this True Tone is a Wells Gardner set. Th...MrFixr55 — 09:31 PM
You should be able to inject an audio signal such as from a CD or mP3into the radio at the volume control. The set will...MrFixr55 — 08:14 PM
Testin a speaker and output transformer Trutone A2-G
Hey Murf, this shouldn't be too difficult if it happens all the time. I'm assuming this is the 1938 Wells Gardner A2 wit...RodB — 05:46 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:25 PM
Hello guy's, Have a Trutone A2-G teledial floor model radio that I am having issues with. Suspecting maybe speaker or ...murf — 03:24 PM
Save the money on the Kapton tape. Just cut an insulator to size out of a clear plastic blister pack and attach it arou...GarySP — 01:13 PM
The thing is when I touch or probe the antenna terminal, the volume control input, the wiper (output), and the primary t...Stormlord5500 — 12:53 PM
Two small radios from France. Restoration and review.
Hello, Vlad. I agree with your description of French radios. I might add that they are made like French cars – extravaga...RadioSvit — 11:08 AM
I do thank you all for helping me out on this.Stormlord5500 — 08:01 AM
