Today's special
hi Brenda
not sure but pic 1 looks like counter balance
here are pic looks like yours is missing wedge that pushes merc switch
[Image: http://i1303.photobucket.com/albums/ag14...ac1d1b.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...03e2d2.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...eac61e.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...2e54d2.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...3d332e.jpg]
hope it helps
sam
Yes, that piece is definitely missing from mine. Does anyone make a repro, or do I need to machine one myself?
Also, what, then, is the purpose of the little free swinging bar?
hey Brenda
looks like turns on and off merc switch
sam
Cartridge was mailed off to West-Tech today. Don't know what the turn around is on that, but hope I can find any other missing parts soon.
I've gotten the service packet for the M-7 phono from Steve. In going over that information, I see some of the parts that I need. I need to find the "spring" (that "T" shaped part on the switch assembly) that activates the mercury switch. Note the difference between my pics and Sam's, this part on mine mounts with the holes at an angle on the mount.
Also, I need to know what thickness of rubber or whatever I need to glue back on to the tone arm actuator arm (the one that is supposed to move the pawl), because even with the little rubber dimple on the pawl, it doesn't come anywhere near the actuator arm. Also, the manual says that this pawl is supposed to contact the mercury switch assembly to turn the switch off at the end of record play, but I can't see where it can contact the assembly at all, let alone be able to turn off the mercury switch.
Everything else seems to be pretty well functional. The idler wheel is intact, the only issue with it is a very small indentation where the capstan had been in contact with it for a long time. It's enough to make a sound as it goes by the capstan, but doesn't seem to affect the platter speed. The rubber is still quite pliable, and I suspect that this small dimple will work its way out of the idler with time and use.
Brenda
I looked at mine they are the same 50Y6 and 35L6
I looked at turn table in your first pic circled when arm comes to center it push's counter balance enough to click player off
the three idlers are rubber caps you can slide them up and off on wood dowels
Correction My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM
[split] New member...
Thanks.  I'll try that.HowardWoodard — 01:13 PM
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
There are currently 1132 online users. [Complete List]
» 5 Member(s) | 1127 Guest(s)
AvatarAvatarAvatarAvatar
