1209 phono help
oops hope this better are a D-10 and a D-10A record players interchangeable in a philco 46-1209 david
David
please re-read your post and correct it. As it stands it is very confusing.
corrected i hope sorry david
D R Ford, as far as I know they both use the same power connection and the same audio connection, trough the same transformer. I might be wrong, but as far as interchangeable go, you could connect an MP3 player or a cellphone to the phono input of your radio and it would work. The D-10 and D-10A have the same footprint (AFAIK) and their only difference would rely in the reproducer.
I personally gave up on the one from my 47-1230 and sent it to another phorum member for his. But I am in the younger bunch who never really used 78 rpm records so I do not think I count.
-Mars
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
