Why did Philco have 2 screws , marked red & black, on a rear of model 116B ?
Threads: 9
City: Joliet,IL.
Hello out their,
I was going to add a audio input jack to a Philco #116B, but I noticed a (2) two screw terminal strip in the rear of the chassis, marked Red & Black ! Might that be for a phono-input , that I can use for my audio input , or were they put their for another reason ? Currently their are NO connections, between them !
Thanks for your help, Lee Petrie, Joliet, IL
Threads: 574
If it is anything like in 37-116, it is not for Phono (well, it is not in your case certainly), in mine they are for some form of loop antenna.
Threads: 9
City: Joliet,IL.
(11-28-2014, 09:32 PM)morzh Wrote: If it is anything like in 37-116, it is not for Phono (well, it is not in your case certainly), in mine they are for some form of loop antenna. Thanks for your quick reply, Morzh, I tried to attach the audio from a CD player to the red & black screw lugs , appears to be NO input from that connection ! I guess I'll do it the old way , on the feed TO the volume control, that I have done before ! Thanks again , Lee Petrie, Joliet, IL. ( 35 miles SW of Chicago )
The RED and BLK screws are for Philco's All Wave Aerial, later called the Philco High Efficiency Aerial. It was a dipole with two twisted leads used as a lead-in. The red wire connected to the RED screw; the black wire to the BLK screw.
A little more info here:
http://www.philcorepairbench.com/mystery/40-6112.htm
If the set owner did not use the special Philco dipole, he or she could connect a conventional longwire to the ANT fahnestock clip on the chassis.
If there are no connections to these screw terminals inside the chassis, then someone has monkeyed with the set at some time.
Threads: 9
City: Joliet,IL.
(11-28-2014, 10:31 PM)Ron Ramirez Wrote: The RED and BLK screws are for Philco's All Wave Aerial, later called the Philco High Efficiency Aerial. It was a dipole with two twisted leads used as a lead-in. The red wire connected to the RED screw; the black wire to the BLK screw.
Hi Ron,
Thanks for the input, It didn't look like a phono input , but I thought I would ask anyway ! I guess I "miss spoke" , I meant to say , their are no wires attached on the outside of the chassis , but inside the chassis their are 2 wires that run to the last "selector switch wafer" , looks like original wiring !
Thanks again for your help, Ron, Lee Petrie, Joliet, IL.
Yes, the end with the groove is positive, the stripe with the arrows points to the negative lead. The arrows have minus ...RodB — 09:36 PM |
Thank you Rod and Paul
I took a break, did some yard work and Rod "Therefore, it appears cap 40 is connected backw...osanders0311 — 06:35 PM |
Philco 45L Initial Check Up
Hello,
I am in the process of checking out a Philco 45L. My question is does this model suffer from the Philco coil r...dconant — 06:11 PM |
Table radio 51C or 52C?
Purchased a table radio at auction, not because I had to have it, but because no one else bid on it. $5 Unable to fi...antiqueradionut — 05:14 PM |
The 2 towns you mentioned "Frustrated" and "Give Up" are places we have all been. Relax, take 5, thi...Paul Philco322 — 03:23 PM |
Philco 89 Code 123 Osc Coil
Thanks for posting that information!klondike98 — 03:14 PM |
From what I see is the blue cap was added by someone after the radio was sold presumably to replace cap 40A. I can't tel...RodB — 03:12 PM |
Correction
My original picture shows #40 cap, blue cap and #42 resistor connected.osanders0311 — 02:23 PM |
Well guys I am stuck, frustrated and about ready to give up. For starters all I'm getting from the speaker is a humming ...osanders0311 — 02:17 PM |
[split] New member...
Thanks. I'll try that.HowardWoodard — 01:13 PM |
There are currently 793 online users. [Complete List] » 1 Member(s) | 792 Guest(s)
