SEPARATING SPIDER & VOICE COIL FROM OLD DAMAGED SPEAKER CONE
I've gotten some great advice on repairing my 1932 Model 43 speaker. I've even seen some great videos on using the coffee filter material and fabric glue to repair holes and tears. However, I saw one informative video where the craftsman actually attached a new cone from MAT electronics to a spider and voice coil from an old speaker where the cone was beyond repair. Basically he did his own re-coning. My question is this--I'm wondering how he separated the voice coil/spider assembly from the old paper cone? Would one brush on a solvent, and then peel off the speaker paper? I think I'm going to use the coffee filter technique for my job, but would like to know about options...in case I botch it up!
I just cut the spider out with an exacto knife.  See http://www.philcoradio.com/phorum/showth...3#pid77053
Thank you, Bob, for clearing-up one more mystery!
Jim
(11-28-2014, 12:35 PM)klondike98 Wrote:  I just cut the spider out with an exacto knife.  See http://www.philcoradio.com/phorum/showth...3#pid77053
I think that's my video you are referring to. The old cone had deteriorated to the point where I just needed to clear away some fragments. I think I did use an exacto knife.
Be aware the foam surround of the MAT cones will stick up above the frame and may press against the cabinet. The foam is also more flexible that the original stiff paper surround. The end result is that it doesn't sound as good as an all paper cone.
Thanks Bob, this is very helpful! Jim
(11-28-2014, 05:19 PM)Bob Andersen Wrote:  I think that's my video you are referring to.  The old cone had deteriorated to the point where I just needed to clear away some fragments.  I think I did use an exacto knife.
When using a cone with a foam surround, be sure to use spacers on the mounting bolts so the foam surround doesn't touch the mounting board.
M R Radios   C M Tubes
Thanks, Steve! I think I will try the "coffee filter patch and glue" method to repair this speaker, since most everything is intact. However, I will keep all this great advice for use when I have a really beat-up speaker to deal with, that requires re-coning.
(12-01-2014, 12:18 PM)Steve Davis Wrote:  When using a cone with a foam surround, be sure to use spacers on the mounting bolts so the foam surround doesn't touch the mounting board.
[split] New member...
You may have to start further back with your signal injection at the IF signal grid, then tune the second IF transformer...RodB — 10:28 AM
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
There are currently 1013 online users. [Complete List]
» 3 Member(s) | 1010 Guest(s)
