Aww! What a cute wittle wadio!
I picked this Philco 41-225 up at the AHRS today for $10. It's going to need a little work, a new cord and such.  The speaker's caved in, but the veener is very nice. A little GOJO and I'm sure it will clean up nicely. I blasted all the dust out of it with some canned air.
Slave to an RCA Victor CTC-25
Took me a while. Widdle means urinating .....?
(05-03-2015, 12:45 AM)morzh Wrote:  Took me a while. Widdle means urinating .....?
Widdle is Baby Talk for "Little" Icon_lol
Or, ...
"widdle wadio" is Elmer Fudd-speak for "little radio".
Icon_smile
This is the smallest Philco I have. Hence, it is a baby.
Mike its "piddle" silly Ruski!
Kirk
You know you could have bot that on Ebay for 100.00! That little set could look slick. Pushbuttons look OK and it has call letters too. It is the right size for about a wall full of say like 50 small Philcos. Good luck.
    This thing's speaker is toast. Does anyone know the power and resistance for it and where I can get a new one? How much does reconing cost?
Well the original FC is 500 ohms which is pretty low. I suspect that's done so there isn't much voltage drop across it. What most later AC/DC set use is a 1000 to 1500 ohm resistor @ 5W. When don't have the FC in the circuit you will need to up the value of the filter caps. The FC provides some filtering the resistor not so much. So replace those with 47mfd @160v. This will give you a nice clean power supply.
As for the recone I'd guess about $45.
I see you got a local set it's got WSM on it.
Kirk, HaHa very funny!!!!!
The current electrolytics are a Cornell Dublier dual cap at 30 and 50 mfd and 150 volts.
(05-03-2015, 09:57 AM)OldRestorer Wrote:  Mike its "piddle" silly Ruski!
Kirk
Though It is a UK version, but it is also what I said.
VerbEdit
widdle (third-person singular simple present widdlespresent participle widdlingsimple past and past participle widdled)
  1. (chiefly UK) To urinate
Thought you did that with a pocket knife and a stick. Didn't know they did it in the UK.
The CD cap is replacement. Original was a dual 20mfd 150v.
(05-03-2015, 12:30 PM)morzh Wrote:
(05-03-2015, 09:57 AM)OldRestorer Wrote:  Mike its "thepiddle" silly Ruski!
Kirk
VerbEdit
English isnt so simple is it?  ; )
Nope. That is, simple enough but since we are separated by the common language that complicates things just a smidge.
(05-03-2015, 02:52 PM)morzh Wrote:  Nope. That is, simple enough but since we are separated by the common language that complicates things just a smidge.
Yea, it doesnt help with all the "slang" terms we all come up with either.
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
Thank for that info Arran! Very interesting. Phillips and Motorola must have made some type of marketing deal back then....klondike98 — 11:49 AM
46-1213 Schematic Question
Good idea on the fuse. These old transformers need extra protection.RodB — 10:02 AM
Hello Larry, Well, anyway I can contest about noisey grounds in my living room when I am using one outlet in my house a...radiorich — 08:03 AM
RodB & MrFixr55, Thank you both for the great replies at my questions, I appreciate the help very much.  As suggest...MissouriLarry — 07:04 AM
There are currently 1420 online users. [Complete List]
» 1 Member(s) | 1419 Guest(s)
