Resistor Part Number
Icon_questionHi All.
Anybody know what value (Ohms & Watts) Philco part number 33-1177 is.
Regards.
Will.
So where would this resistor be used???
will
please list radio model and schematic for help
sam
Thank you for your replies Guys.
Its a philco 640B Aka philco98 export.  See Here.
http://www.philcoradio.com/phorum/showth...p?tid=5299
Ron sent me a copy of philco service bulletins some time ago and No 221 suggests changing resistor 6650 (20K) for part number 33-1177.
I have returned to this set after a while away from it  (been busy with work in this recovering economy) and found that the voltages are all over the place, also broadcast band is silent.   So in my wanderings around the circuit this popped up.
Regards.
Will.
Hi Will,
I would suspect that 20K is OK as it's mentioned in the service notes. If you are finding hard to get the voltage readings I would start at the power supply to be sure that the output is what it should be. Without that baseline you'll be chasing your tail trying to get to work. After the power supply then the audio stages.
GL Terry
hotwire
I fixed your link so we can follow along
sam
Tnx Sam,
 I opened it but didn't know where it was going...
First Radio restoration
There are currently 1603 online users. [Complete List]
» 2 Member(s) | 1601 Guest(s)
