need color advice
I am digging into a very nice 53-960 and it will need stripping and refinishing. What color of Mohawk lacquer is correct for this model?
(07-25-2015, 01:09 AM)doc612 Wrote:  I am digging into a very nice 53-960 and it will need stripping and refinishing. What color of Mohawk lacquer is correct for this model?
The Philco gallery says its the wood used was mahogany, and it looks reddish like mahogany in picture, I would go with that. There are different shades of mahogany, pick one that you like the best and run with it.  If the wood on cabinet is in good shape, just grain fill and sand with 240 grit or higher ,the film off leaving filler in pores only ,  and then clear it with lacquer, you should be fine
Mahogany it is. Thanks.
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
5U4 vs 5Z4 tubes
By the way. osanders0311 Take a look here: Dial cord stringing Guides May be here you can fount correct string settin...Vlad95 — 11:15 PM
There are currently 1079 online users. [Complete List]
» 1 Member(s) | 1078 Guest(s)
