37-10 plate voltages 100 vdc high
Threads: 3
City: Boise Idaho
Outputs 2 (6f6g), 6k7g (if); 6k7g (rf), voltages all 100 volts high.
Possible cause and or possible fix, and or any help i can get.
Thanks as always to those more wise than me.
TT
Threads: 270
So post some pics of the top and under the chassis. Let's see what you've got.
Threads: 276
City: Wilsonville
State, Province, Country: OR
TT, do you mean a 38-10? The 39-10RP is a phonograph that was attached to a radio.
Threads: 33
City: Horsham, PA
Have you done anything with the radio (like recapping it and checking resistors)? If the answer is no, then don't power it up again until you do.
Good luck.
Threads: 3
City: Boise Idaho
(08-21-2015, 07:00 PM)Radioroslyn Wrote: So post some pics of the top and under the chassis. Let's see what you've got.
Its a 37-10 sorry.
Threads: 276
City: Wilsonville
OK, here's the 37-10 schematic. Have you recapped the set?
Threads: 3
City: Boise Idaho
I have schematic and it has been re-capped. Changes per #269 revisions were made.
Threads: 270
The reason I asked about pics is I wanted see if the power transformer is original to the set among other things.
Threads: 276
City: Wilsonville
Here are some instructions for adding pictures. I added the link to the schematic to make it easier for folks to help you.
Threads: 3
City: Boise Idaho
(08-24-2015, 05:49 PM)Radioroslyn Wrote: The reason I asked about pics is I wanted see if the power transformer is original to the set among other things.
Terry Ok. I'll give the picture thinga shot. I have to find a site to put them on, so i'll need a few days tofigure it out.
As always, thanks philco folks.
Threads: 3
City: Boise Idaho
(08-24-2015, 07:56 PM)klondike98 Wrote: Here are some instructions for adding pictures. I added the link to the schematic to make it easier for folks to help you.
Will it work if i put pictures in dropbox?
Threads: 276
City: Wilsonville
Yes, I use dropbox. You put the pictures you want to share in the "public" folder.
Threads: 3
City: Boise Idaho
Threads: 270
I might be doing it wrong but all I'm seeing is thumbnails.
Threads: 276
City: Wilsonville
When I click on hhe thumbnail using a chrome browser, it opens to a larger pic for me.
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM |
Thank you for the detailed response MrFixr.
To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM |
MrFixr
The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM |
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM |
Hi SQ55,
A strange issue indeed! Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM |
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM |
schematics
Ohrenet :roll:
For their price I would chase a fly in a field. :twisted:Vlad95 — 11:21 PM |
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM |
schematics
Often restuffed.
If a twistlock, Hayseed Hamfest makes modern replacements.
morzh — 09:18 PM |
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM |
